JUICEDMOTORSPORTS
Old 09-03-2013, 11:32 AM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Brake Ducts Installed on my 1LE (DIY)
I had been planning to install some brake ducts on my 1LE since I first got it in May, but after 3 track days on the stock calipers/rotors/pads and Motul 600 and not doing "much" late braking I was pleasantly surprised with the stock set-up.
I decided to add ducts before Grattan this past weekend on pretty much the morning I was scheduled to leave.......so my choice of parts was out of my last minute decision, not out of long term planning I would have preferred a more conical duct entrance so the air wouldn't be turbulent entering but I couldn't find one small enough for the area I wanted to use and these were very cost effective.
Parts used:
  • 1 Tube of 3" x 10" of Neoprene 2 ply brake duct material (you only need about 3' total) about $80.00....you can by yours for about $20
  • 2 random metal brakets with holes that can be bent / formed to hold the tail of the duct in place (I had them in my garage)
  • 2 Long zip ties (also in my garage)
  • 2 " Air Intake Mount made by Spectre p/n 8148 (2 x $5.99) purchased one at Advanced auto parts and the second at O'Reilly Auto parts
  • 8 push clips: I used these because I have tons of them in my garage (nut/bolt, pop rivet and other items will work)
  • 2 Hose clamps (from my garage)
Why I chose the position I did to gather the air:
  • I copied the routing from the ZL1
  • It is a straight shot from front to the area it dumps air
  • It was easy to mount my inlets
  • I had coffee with the High Performance Brake Engineer at GM that worked with the brake system and he told me not to grab the air from the fog light openings (remove lights) as it was warmer and more turbulent out there.
If you look at the picture that has the ZL1 air guide(top) and SS/1LE (bottom) you can see were SS is wider because the ZL1 has the ducts in that area. It appears the Camaro was designed from the get go to have brake ducts as there is room on either side between the frame rail and the washer bottle on the drivers side and between the rail and the radiator overflow on the passenger side to fit 3" ducts (thanks GM!)
General Overview:
  • Remove front fascia and set aside (NO modification needed at all)
  • take your Air inlet and eyeball it/ square it up on the flat section of the lower air guide (still on the car) (see pic)
  • Drill your hole with a hole saw (see pic)
  • Clean up edges of the new hole with a file or razor blade
  • Mark and drill 4 holes to insert your clips or nut/bolt to hold the inlet to the air guide
  • NOW READ CAREFULLY: the 3" brake duct ID is the same size as the 3" air inlet OD....they will not slip together with out a slight mod to the duct. The duct has a metal wire for support in it. You will need to use a pair of wire cutters to "snip" about 3 of the wires at the same point. Do not cut the material, just make 3 snips of the wire in a row to release the tension and allow the duct to slip over the air inlet. (see pic)
  • Attach the hose to the air inlet and then feed the hose through the hole in the air guide (DO NOT install the hose clamp yet...it will not fit through the hole)
  • Secure the Air inlet to the air guide, install hose clamp.
This is where you will need to be a bit creative with the bracket to hold it up on the end closest to the wheel well
  • There is a bolt holding the washer bottle in place....remove it as this is where you will take your random metal bracket and mount it. (use the radiator overflow bolt on the passenger side)
  • Adjust your bracket until it holds the duct in place.
  • NOT PICTURED: I coated my random metal brackets with Black plastic dip just to make it look a little more stealth
  • Install a zip tie around the duct and secure it to the random metal bracket.
  • Repeat on the other side
  • Reinstall the front fascia
  • Smile and pat yourself on the back for a job well done!
I ended my my brake ducts at the front edge of the wheel wheel just like the ZL1 does. A true "racecar" brake duct will end at the backside of the hub/inside of the rotor but I didn't see any easy route and was frankly running out of time as I had to load and get to the track....
I did test them in my personal wind tunnel = A leaf blower on the front of the car and I was able to confirm my race car scientific theory: there is a lot of air coming out the duct and dumping into the back of the hub area....
Pictures Speak 1000 works....See below
FYI: I have enough extra material to supply 1/2 person with a DIY kit for a small fee. DO NOT ask me here please...PM me.
-Matt
Old 09-03-2013, 11:32 AM   #2
Dropspeed
Dropspeed's Avatar
More Pictures
Old 09-03-2013, 12:12 PM   #3
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
That's a great job.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 09-03-2013, 12:26 PM   #4
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
I love this site!!
tramtwo is offline   Reply With Quote
Old 09-03-2013, 12:35 PM   #5
Synner
Drives: not stock
I will be using this kit since it should have a bit smoother airflow at the entry point
http://www.jegs.com/i/Kenny+Brown+Pe...1300S/10002/-1
Or get 2 of these separately but when I added up the hose and clamps it was about the same price.
http://www.jegs.com/i/Allstar+Perfor...42140/10002/-1
Will be using the quantum kit for the hub brackets.
Old 09-03-2013, 01:41 PM   #6
Dropspeed
Dropspeed's Avatar
Those ducts will work much better and would be preferred...but being that they are 5.5" tall they will not fit in the same location without some cutting/fab to get them in there as there is only about 4 to 4.5" of space.
This one that is 6" wide and 3.5" would fit better in there: https://www.pegasusautoracing.com/pr...p?Product=3623 and I will be changing over to this one during the winter utilizing the same location
FYI: You can piece together a kit from Pegasus for much cheaper than the kit from Jegs
https://www.pegasusautoracing.com/ad...ryID=BRAKEDUCT
I did not get mine stuff from here, but I have used them in the past..
-Matt
Old 09-03-2013, 01:58 PM   #7
Synner
Drives: not stock
I found it a good bit cheaper, just the quickest link to find. I will cut as much of the side area away to still be able to rivet it together, 4.5" should be enough to work. I'll see if I can get the ducts that come with the kit to fit otherwise I did waste some money. Heck I'll use the extra ducts and hose to put some on the wifes corolla so she thinks I'm even crazier.
Old 09-03-2013, 02:21 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Nice work! We have been running the quantum brake duct kit on the JDP Camaro. I like the quantum kit because it actually channels air directly into the cooling vanes of the rotor.
Feel free to call, PM or email me with questions.
Best regards,
Tyler
888-308-6007
Old 09-03-2013, 02:36 PM   #9
Dropspeed
Dropspeed's Avatar
Best regards,
Tyler
888-308-6007
Very cool, I was not aware of Quantum......Looks like I will be making two changes over the winter, different Inlets and the Quantum kit!
Thanks,
Matt
Old 09-03-2013, 02:40 PM   #10
Synner
Drives: not stock
http://www.lapponline.com/index.php?...roducts_id=234
Old 09-03-2013, 03:07 PM   #11
Dropspeed
Dropspeed's Avatar
Three questions:
  1. Does it work with both the SS and the ZL1 calipers? (If I upgrade later)
  2. Does the ZL1/1LE backing plate need to be cut off or does it unbolt (I can really just look later)
  3. Can I purchase the kit from you without the ducting?
Thanks,
Matt
Old 09-03-2013, 03:23 PM   #12
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Best regards,
Tyler
888-308-6007
I really need to do this,as i brake late and hard.Man, at Fontana a couple weeks ago i couldn't even hold my lug nuts they were so hot.I wont be able to afford this till after Christmas,but is there an instruction sheet that you can post so i can see if this is even something i can do by myself?
cornerspeed92 is offline   Reply With Quote
Old 09-03-2013, 11:43 PM   #13
toehead93
Drives: 2014 2SS/1LE
Great post and photos, I have a much better idea of how this all works now. I've put together the following parts which I have yet to order. I am not sure which inlet duct will fit best so I have two sizes listed. This list comes to about $125 for parts:
3630-3.00-6 FOOT Neoprene 2-ply Air Duct Hose, Black, 3.0" x 6 Foot
https://www.pegasusautoracing.com/pr...p?Product=3630 $38.49ea x1
3623-Color Air Inlet, Extra-Small Rectangle, 6 x 3.5 inch https://www.pegasusautoracing.com/pr...p?Product=3623 $18.99ea x2
3613-3.25 SS Worm Drive Hose Clamps, 2.25-2.75, 3.25” ID https://www.pegasusautoracing.com/pr...p?Product=3613 $3.20ea x4
ALL42116 Allstar Performance LH Aluminum Single Spindle Duct
http://pitstopusa.com/i-5066463-alls...ghtweight.html $24.94ea x1
ALL42117 Allstar Performance RH Aluminum Single Spindle Duct
http://pitstopusa.com/i-5066464-alls...ghtweight.html $24.94ea. x1
7022 ButlerBuiltŪ Headlight Mount Duct, 7.75" x 5.5"
http://pitstopusa.com/i-5063720-butl...-75-x-5-5.html $11.83ea x2
Alternate, the spindle unit will be a much simpler install but does the 45 degree angle perform better than the 90 degree angle to the rotor surface? The spindle units look like you can drill holes where needed to align with existing spindle screw locations.: R46-003 Richardson Aluminum Single 45° Air Duct
http://pitstopusa.com/i-5085152-rich...-air-duct.html $27.87ea. x2
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-04-2013, 11:00 AM   #14
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
Should this go in the main DIY section of the forum? I would think this mod could work on just about any 5th gen Camaro
flyinlow is offline   Reply With Quote
