Old 09-03-2013, 08:05 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2010 Camaro 2ss M6
Which way to go?
I looking into getting gears for my car soon and have been told I need to get some suspension mods to help with wheel hop.
Which way is better to go for now? (plan on doing more but will be a long time from now.
Should I just get something like this?
http://www.ohio-speed.com/p-880-2010...ars-20104.aspx
Or, start doing toe rods, trailing arms, etc......?
Thanks!
TheBandit18 is offline   Reply With Quote
Old 09-03-2013, 10:36 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Subframe Bushings, Trailing Arms, Tie Rods, and a Good Alignment
Old 09-04-2013, 12:16 AM   #3
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
+1
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 09-04-2013, 06:38 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This. Forget that brace. Wheel hop is very simply a rapid and repeated loss and recovery of traction. When a car begins to accelerate various bushings and suspension/chassis components (primarily the ones listed above) flex. Under normal driving conditions this flexing is negligible but when the car is launched aggressively the deflection causes significant toe changes which reduce the contact patch of the rear tires. This leads to a reduction in traction and momentary wheel slippage which alleviates the toe changes and allows the rear tires to regrip. The vicious circle then continues as the suddenly improved traction again results in grip and therefore causes the flexing and toe changes which again leads to wheel slippage.
By upgrading the components known to be responsible for the flexing with stronger/stiffer aftermarket units you will lock the rear suspension geometry in place and significantly improve grip and performance. Earlier this year I put together a rear suspension set up for one of our locals that resulted in a 3 tenths improvement over his previous personal best the very first pass he made down the strip. If you have any questions feel free to send me a PM or give us a call.
Old 09-04-2013, 07:58 AM   #5
TheBandit18
Ok. What brand would be the best to use?
Old 09-04-2013, 08:39 AM   #6
Apex Motorsports
Which parts specifically to go with depends on a few things.
1) How exactly do you use your car? (street only, street/strip, street/auto-x, etc)
2) How much power do you put down?
3) How much power do you anticipate making in the future?
Old 09-04-2013, 08:52 AM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks!
The part you have in that link will only help very minimally when it comes to wheel hop. That part is really designed to minimize chassis flex.
Like others have said the real way to eliminate wheel hop is to minimize the movement in the rear end/rear cradle/ rear suspension. Every car is a little different and there are many variables that go into wheel hop so it can take different parts to alleviate wheel hop on different cars. For me to be able to recommend anything to you I would really need to know some details on the car and what your goals are for it. The best thing to do would be to either give me a call here at the shop or shoot me a PM and I can throw some recommendations out to you.
Generally these are the parts that are going to make a significant difference in controlling the wheel hop:
trailing arms
outer trailing arm bushings
toe rods
rear cradle bushings
differential bushings
upper control arm bushings
A good alignment will also help out quite a bit because it will insure that you have the largest tire contact patch possible which will help make it easier to get the power to the ground.
Give me a call and we can definitely get you taken care of.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 09-04-2013, 09:02 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Actually, from my experience, the Hotchkis chassis brace will really do very little if anything at all for you. I had one for a while and all I can say is I don't anymore. You can add much better parts for the money.
For me the best thing that killed a majority of my wheel hop was Trailing Arms. Just those alone helped a ton. Cool thing is they are relatively cheap, easy to install, and no alignment necessary.
After that I would say that cradle bushings was then next best thing. I could really feel the firmness of the rear. I'm only putting down about 412 rwhp so I just installed the cradle bushing inserts for now. They were cheaper, easier to install, and I can probably sell them for a little money down the road if I ever go full bushing. I suggest Pedders for those.
From there you can go to coil overs, rear end bushings, etc. but IMO if you were to just do trailing arms (with bushings) and a set of cradle bushing inserts (if you're in the 500 rwhp range go full bushing) you'll be really surprised at how well that will make a difference.
Build Journal
Old 09-04-2013, 10:38 AM   #9
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Exactly what Chase just asked...
I really like Pfadt's Stage 3 Kit
http://store.pfadtracing.com/camaro-...e-kit-stage-3/
If you want to go all out, their Stage 4 Kit
http://store.pfadtracing.com/camaro-...g-kit-stage-4/
JT
Team STILLEN is offline   Reply With Quote
Old 09-04-2013, 11:41 AM   #10
TheBandit18
I'm around 480rwhp right now and 430rwtq. I plan on getting up there in power 700-750hp tops.
It's my daily driver right now an I go to the drag here and there but would like to do the circuit sometime.
Old 09-04-2013, 12:19 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
With what wanting to do and the power you plan on making here are the BMR parts I would recommend for you to not help with handling but also take care of the wheel hop.
BMR adjustable trailing arms w/ spherical rod ends (TCA033)
BMR adjustable toe rods w/ spherical rod ends (TR004)
BMR 1" lowering springs (SP019)
BMR rear suspension bushing kit (BK021)
BMR sway bar kit (SB037)
BMR solid delrin rear cradle bushings (BK027)
BMR "pro" differential bushings (BK029)
If you are interested let me know and we figure out what pricing would be for you on a custom package like this.
Kyle
T.C. Davis
813-986-9302
Old 09-04-2013, 12:23 PM   #12
Apex Motorsports
With that kind of a power goal I would recommend solid rear cradle bushings. Solid is a scary word when it comes to suspension but with the rear cradle you can get away with it, even on daily driver applications. BMR and Pfadt both have great solid rear cradle bushing options. For the kind of use and power you are describing I would probably go with BMR trailing arms and toe rods, just be sure to also order the outer rear trailing arm bushings as they are not included. If you have any questions of would like a quote just hit me up.
Old 09-04-2013, 01:04 PM   #13
caverman
caverman's Avatar
ADM Performance has solid rear bushings as well. From what I saw they were the best priced ones out there. It's at least worth you looking at.
Build Journal
Old 09-04-2013, 07:09 PM   #14
TheBandit18
ill be getting in touch with a couple of you guys. I don't have that much money to spend so I might have to buy parts at a time.
