Gen5DIY
Old 09-04-2013, 05:40 AM   #1
NAZR1
Drives: ZR1
Need Help with Kenne Bell Liquid Cool SC
I am tossing up the idea to install the KB 3.6 on my ZR1. Does anyone with a camoaro SS live close to Maryland where I could get some measurements?
Or maybe send me some measurements? I am concerned if this blower will clear the cowl or not.
NAZR1 is offline   Reply With Quote
Old 09-04-2013, 10:32 AM   #2
NicKey
Drives: Nickey Super Camaro
The Mammoth Intake behind the Blower does rest up against the cowl. You may need to bend the sheet metal for some additional clearance. But no cutting is required. The ZL1 Scoop / insert will need to be modified, but the stock ZL1 hood w/o the insert will close/clear most pulleys.
NicKey is offline   Reply With Quote
Old 09-04-2013, 10:41 AM   #3
Unreal
Drives: 2006 Z06
He said zr1 not zl1. I don't think there is any way it is fitting on a vette.
Nick
Corvette Z06 -1200ish rwhp
Old 09-04-2013, 11:30 AM   #4
NicKey
Thanks for the correction.
Old 09-04-2013, 03:15 PM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
If there's will there's a way, but in this case you'd need a huge cowl hood, or a cutout that it could come up through the hood to fit one; which would look pretty damn cool.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-04-2013, 04:45 PM   #6
Unreal
Drives: 2006 Z06
It would be more than a cowl hood, it would be cutting the whole cowl/wipers/etc out and maybe notching the glass on the windshield.
Nick
Old 09-04-2013, 07:09 PM   #7
2SS45th
2SS45th's Avatar
I didn't know that ZR1's cowl was that tight on the motor, that pretty much ruins the plan, at least in my book it would.
Old 09-04-2013, 10:26 PM   #8
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
I had a 2.8L on my 99 C5. Biggest pain in the A$$ mod I've ever done, and I've got one hell of a resume. Yes, they make power and are built well, but if you ever need to change plugs or remove valve cover for some remote reason, get out your tools for the day.
I now have an SLP TVS2300 I installed in 5 hours with no hose or wire cutting/splicing. Absolutely love this blower. Fits amazing and everything around the motor is easy to get to without removing the head unit. I know the TVS is not for your application, but there are other big liter blowers for making more power and still make your life simpler.
white1LE is offline   Reply With Quote
Old 09-05-2013, 12:21 AM   #9
sting808
Drives: 2010 SS RS
Same here. Hindsight being 20/20, the new Maggy/SLP design or Whipple would be my choice for a top mount design. Also, the mammoth intake blocks the AC fitting for recharge. From another KB 2.8LC owner that looked for a possible vacuum/intake leak, changed injectors 1-1/2 years later, and modified the driver-side valve cover...
Still runs great and nice subtle whine up front.
sting808 is offline   Reply With Quote
Old 09-05-2013, 07:50 AM   #10
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I can not imagine that install is possible at all. Here is the clearance between my eforce and cowl, (about enough to slip a piece of paper through) and I believe the eforce is much lower.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is online now   Reply With Quote
Old 09-05-2013, 07:52 AM   #11
ayousef
ayousef's Avatar
Drives: 2013 ZL1
noway that thing would fit, you could fit a whipple 2.9 with a custom hood (which look ugly on Corvettes) and still not make SOO much more power compared to the stock blower.
Is your stock ZR1 maxed out?
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 09-09-2013, 11:32 AM   #12
NAZR1
Drives: ZR1
I have maxed it out and it is not happy so I have the 2.6 upper and 14% lower pulley.
Old 09-10-2013, 02:47 PM   #13
Crawler
Crawler's Avatar
Drives: 12 2SS L99
Twin turbo setup feeding the 2.3 FTW.
Instant throttle response and insane topend.
Crawler is offline   Reply With Quote
Old 09-10-2013, 04:58 PM   #14
2SS45th
2SS45th's Avatar
The supercharger can't handle the added pressure, we've been blowing superchargers up in the diesel world for a while when trying to use turbos before it.
