Old 09-08-2013, 07:11 AM   #1
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Post UNDER PRESSURE
What systems or mods work to reduce crankcase pressure.
What are you using.
Vac Pump
Exhaust Venting
Breathers
etc.
Bad Dad is offline   Reply With Quote
Old 09-08-2013, 07:45 AM   #2
Bad Dad
Bad Dad's Avatar
THIS
Old 09-08-2013, 08:01 AM   #3
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
This - http://mightym0use.wix.com/mm-solutions#!mm-og/ca5m
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 09-08-2013, 08:47 AM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Originally Posted by Rockit_z28 View Post
I like the way this person does his business
Motion427 is offline   Reply With Quote
Old 09-08-2013, 11:26 AM   #5
blake-b
blake-b's Avatar
Drives: Black 2010
What I used and it cured my rear main seal leak.
Old 09-08-2013, 11:29 AM   #6
Supercharged SS
Drives: 2010 Camaro
Dual catch cans and a valve cover breather. I was pushing oil through the rear main like a mofo. Not a drop in two years now. The new valley cover we are using also as a port to vent pressure.
Old 09-08-2013, 08:18 PM   #7
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Im running a MM can on my boosted Trans AM, no problems at all.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 10-20-2013, 10:19 PM   #8
blufin
blufin's Avatar
Drives: Fire Engine
How is the MM different than a standard catch can? I've got the Elite. I also thought the oil cap vent was a bad idea.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 10-21-2013, 12:03 AM   #9
blake-b
blake-b's Avatar
Drives: Black 2010
Might mouse can uses the stock oil cap. A line runs from each valve cover to it's own port on the bottom of the can. The can has metal mesh in it just like an elite. There is a blow proof metal PVC valve at the top of the can. You run a line from it to the intake.
The top cap screws on and there is a thick rubber diaphragm under it. Under normal conditions, the diaphragm is closed. If you are making enough crankcase pressure, the pressure forces the diaphragm edges up and it vents it to the atmosphere.
If you are running a centri blower or a turbo, you also run a line from the valley cover to the air filter or otherwise to the centri/turbo.
It only vents when necessary and is otherwise a closed system til pressure makes it open.
Other threads about the MM can:
http://www.camaro5.com/forums/showthread.php?p=7019872
http://ls1tech.com/forums/forced-ind...catch-can.html
http://www.camaro5.com/forums/showthread.php?t=310144
