09-08-2013, 10:42 AM | #1 |
Drives: 10 Camaro SS Join Date: Sep 2011
what to do
10 SS 6sp with cai , cam , headers , hfc , dyno at 450 , 420 at wheels , stock tires. 60ft times as follows : 2.905 , 2.818 , 2.669. 1/4 mile speed : 105,106,107. I am installing a zl1 drivetrain with 3.73 gears. would I be better off with 20 in dr or 18 in ? also installing a line-lock . thanks for any advise.
09-08-2013, 10:55 AM | #2 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
18 in DRs for sure. But practicing the launch is going to give you more gain than anything else you can do.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
09-08-2013, 11:19 AM | #3 |
^^^^ What he said!!! But jeez, for having a cai, cam, and headers, I sure would hope for better RWHP numbers than 420?!?!? I don't know, I'm certainly no expert, that just seems a little low to me. Who tuned it? The 373 gears will help a little, but definitely get rid of the 20" stock wheels/tires. Go with 18's or even 17's (if your budget can handle it). And some rear suspension mods would also help. But as previously mentioned....practice, practice, practice!!!
09-08-2013, 11:23 AM | #4 |
Drives: 2010 F450 Join Date: Sep 2013
18" for sure
09-08-2013, 11:36 AM | #5 |
Drives: Fire Engine Join Date: Oct 2008
Lots of seat time needed here. That 60' need a lotta work. Even on street tires, good 60' times can be had with practice.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile 11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires. Sold |
09-08-2013, 03:58 PM | #6 |
I have all BMR upgrades to rear suspension with BFG tires at 32lbs. All nannies off and have launched at 2000 to 4000. I either smoke the tires or wheel hop. I have had a lot practice but I am still missing something. Maybe go to automatic trans. Thanks for all advise. Tried slipping clutch same result.
09-08-2013, 07:18 PM | #7 | |
09-08-2013, 08:28 PM | #8 |
Sorry about the tires. Tires are BFG Sport Comp 2 and yes I have cradle bushings ,trailing arms ,toe arms ,sway bars , end links, subframe connectors .
09-08-2013, 08:43 PM | #9 |
Well, sounds like you got the suspension covered. My best 60' on 20" Continental DWS "all-seasons" was 2.03 (Manual LS3). I would think you should be able to beat my time with the tires you have. I've got lots of suspension mods, but very little experience and I realize I need better tires and a LOT more practice. The only advice I could give is drop down to 17" or 18" drag radials and see what happens. Line lock is good for the burn out, but that's about it.
09-08-2013, 09:04 PM | #10 |
I think the plan will be 18 tires and lots more practice. being a senior citizen does not help my times either. hope my clutch holds up. thanks all for advise.
09-09-2013, 06:24 AM | #11 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Good luck
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
09-09-2013, 07:34 AM | #12 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
I would not even bother with tires right now, your 60ft needs allot of work.
10.91 at 122 H/C stock block N/A
09-09-2013, 09:31 AM | #13 |
Drives: 2010 rs/ss black # 10,308 Join Date: Mar 2009
18" DR's would nice. But agreed with others that you will need more seat time.
From the looks of those 60' times... i would say you are either spinning of the line or bogging to the point where your car is shutting off. It does take a good amount of seat time to master launching any car. So the more trips to the track the better. Best advice i can give by looking at those times are try taking off like you are taking off aggressively from a red light. Doing that will net you a better 60' time right there.
09-09-2013, 12:56 PM | #14 |
Drives: Race Car Join Date: Sep 2009
Getting a good set of 18" wheels and drag radials would definitely make it quite a bit easier to launch your Camaro because those 20" stock wheels and tires are not helping you at all. Honestly no matter what tires you run it is going to be a challenge to launch the car and do it consistently. Another thing that is just as important as the tires is going to be practice. The more seat time you have at the track the better you will be at launching the car and the better your times will be. You have the suspension to be able to do it you just need the tires and the practice.
Thread Tools | |
