Caryle Racing
Old 09-08-2013, 09:48 PM   #1
No_Traction_B
No_Traction_B's Avatar
Drives: 2010 Camaro SS D1SC
Thumbs down Methanol injection questions
Ok guys, this can be a thread for some who are wanting to learn more for methanol injections, I know I have tons of questions myself and I'd be interested in hearing yours too. So shoot.I've heard running 50/50. 70/30. And 100% methanol....... So you can see we're my confusion begins... I've recently purchased an AIS system with dual spray setup. This will be going on a camaro with d1sc with blower cam and other supporting mods currently making 700rwhp. Soo what ratio is safest and healthy for the motor as well as making some more power. Thanks alot!!!
No_Traction_B is offline   Reply With Quote
Old 09-08-2013, 09:56 PM   #2
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
I was told to run 100% meth and I'm 700+ RWHP on a Vortech. I got more than enough fuel so meth is only to bring AITs down not as a fuel replacement or power.
DarkCry956 is offline   Reply With Quote
Old 09-08-2013, 10:01 PM   #3
No_Traction_B
Are you running stock bottom end?
Old 09-08-2013, 10:02 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
1026rwhp here with ysi on forged rods/pistons, stock crank. . 100% meth. Not tuned for meth just added as a safety feature. I have an alky control dual m10 nozzle setup with MAF reference.
Old 09-08-2013, 10:04 PM   #5
Supercharged SS
Drives: 2010 Camaro
That's incorrect. If you are looking for cooling you want it at least 50/50. It's the water that cools not the methanol.
Old 09-08-2013, 10:10 PM   #6
No_Traction_B
See what I mean.... Getting two different recommendations.... Who to believe.? This needs to be broken down and looked at.
Old 09-08-2013, 10:13 PM   #7
blake-b
blake-b's Avatar
Drives: Black 2010
I went off the recommendation of Julio at alky control and my intake tube gets cold to the touch when meth gets added.
Old 09-08-2013, 10:15 PM   #8
No_Traction_B
Matt @ fsp recommended 100% as well.
Old 09-08-2013, 10:17 PM   #9
blake-b
blake-b's Avatar
Drives: Black 2010
You could try all ratios and datalog and see which cools the best.
Old 09-08-2013, 10:20 PM   #10
Supercharged SS
Drives: 2010 Camaro
So why do people add distilled water? Think about it.... Can't burn water...
Old 09-08-2013, 10:21 PM   #11
Supercharged SS
Drives: 2010 Camaro
100% meth is a great saftey net. Yes, it will aid a little in cooling but if you are looking for the full benefit it needs to be near a 50/50 mix.
Old 09-08-2013, 10:21 PM   #12
No_Traction_B
Very true. But that would requir me getting it re dyno tuned every time I swap ratios. That can get expensive I'd like to have the right ratio the first time around.
Old 09-08-2013, 10:23 PM   #13
blake-b
blake-b's Avatar
Drives: Black 2010
Maybe it was because the older pumps couldnt handle straight meth? I honestly dont know. It seems everything I have read says 100% meth makes the most power. You arent cooling in the combustion chamber you are cooling the intake charge. Where is a scientist or chemist when you need one?
Old 09-08-2013, 10:26 PM   #14
blake-b
blake-b's Avatar
Drives: Black 2010
http://www.camaroz28.com/forums/forc...ection-491444/
didnt read all of it yet but seems to support Jamie for pure cooling purposes.
