BORLA
Old 09-08-2013, 10:27 PM   #15
Supercharged SS
Drives: 2010 Camaro
Originally Posted by blake-b View Post
Maybe it was because the older pumps couldnt handle straight meth? I honestly dont know. It seems everything I have read says 100% meth makes the most power. You arent cooling in the combustion chamber you are cooling the intake charge. Where is a scientist or chemist when you need one?
http://www.stangtv.com/tech-stories/...injection-101/
Yes, 100% meth for max power. 50/50 for optimum power/cooling.
Old 09-08-2013, 10:28 PM   #16
No_Traction_B
No_Traction_B's Avatar
Drives: 2010 Camaro SS D1SC
I agree. I was told the water burns of too fast and the methanol is more important.
No_Traction_B is offline   Reply With Quote
Old 09-08-2013, 10:31 PM   #17
Supercharged SS
Drives: 2010 Camaro
How are you burning water?
The water evaporates then cools.
Old 09-08-2013, 10:37 PM   #18
No_Traction_B
Evaporates yes...
Old 09-08-2013, 10:41 PM   #19
Supercharged SS
Drives: 2010 Camaro
Evaporates yes...
The water (evaporates) vapor cools
The methanol (burns) making power.
The mixture comes down to what you want more of.
Old 09-08-2013, 10:47 PM   #20
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Are you running stock bottom end?
Yes stock bottom end
DarkCry956 is offline   Reply With Quote
Old 09-08-2013, 10:48 PM   #21
DarkCry956
DarkCry956's Avatar
Originally Posted by Supercharged SS View Post
That's incorrect. If you are looking for cooling you want it at least 50/50. It's the water that cools not the methanol.
Well my tuner recommended this as well as Julio from Alky. Is my tuner wrong?
Old 09-08-2013, 10:52 PM   #22
No_Traction_B
I think that is very will put and most likely the answer to the question ,, the ratio should be determine on what you desire, cooling or more power.
Old 09-08-2013, 10:52 PM   #23
Supercharged SS
Drives: 2010 Camaro
http://www.camaroz28.com/forums/forc...ection-491444/
didnt read all of it yet but seems to support Jamie for pure cooling purposes.
Matt's not wrong. You will get minimal cooling affect with straight meth inject.
You will NOT get max cooling without water being injected as well.
Ask yourself "why do people use a water/meth mix if the water portion is pointless"?
If you read the articles linked above you'll get some great info and be able to decide for yourself what is best for you.
Old 09-08-2013, 10:53 PM   #24
killmode_on
Drives: 2011 2SS/RS
The cooling effect of meth is greater than water. People put water in it to stabilize it, to dilute it, or to lower out of control combustion temps. It is much less corrosive when some water is mixed in and that can be a big deal with some pumps and fittings. And it evaporates less with some water mixed in.
Be vewy vewy quiet, I'm hunting GT500's.
killmode_on is offline   Reply With Quote
Old 09-08-2013, 10:57 PM   #25
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
100% meth is a great saftey net. Yes, it will aid a little in cooling but if you are looking for the full benefit it needs to be near a 50/50 mix.
Aid a little??? My iat's on the dyno went from 90degrees to 47degrees w/ 100% meth alky control kit...
Seems more than a little to me.. JMO
ddck24 is offline   Reply With Quote
Old 09-08-2013, 10:59 PM   #26
Supercharged SS
Drives: 2010 Camaro
Just imagine of you had a water/meth mix.
Old 09-08-2013, 11:01 PM   #27
DarkCry956
DarkCry956's Avatar
Well ill let my tuner decide or chime in
I'm hardly spraying meth. When I press the purge I don't see changes in AFR till after 20-30 seconds. If its not for cooling and not for power then idk. I thought people wouldn't run 100% meth because the system wouldn't handle it
Old 09-08-2013, 11:04 PM   #28
avellanet.jr
Emerald Coast Camaros
avellanet.jr's Avatar
Drives: 2014 ZL1 #77
I'd like to know as well. Meth will be part of my build plans here shortly after I add some more upgrades.
Matt@FSP has a kit I'm going with, not sure what we plan on using.
Current Car: 2014 ZL1 #77
Old Car: 2012 Camaro 2SS LS3 45TH Edition
avellanet.jr is offline   Reply With Quote
