Cold Air Inductions
Old 09-09-2013, 12:06 AM   #1
The Baron
The Baron's Avatar
Drives: 2013 zl1
gt500 slayer is comin around
Finally getting this thing to run the numbers more consistent
went to LsFest this weekend and made some good passes
10.42
10.32
10.28
all still on the 20" drag radials.. it went a 1.48 60 !!
Im slowly leaning on it a bit more and more.. I never get to race it in the evening so hopefully when I find some air I can get down in the teens where I want to be on these tires.
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 09-09-2013, 12:14 AM   #2
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
Very nice times, cooler weather is a comin'
Evotion is offline   Reply With Quote
Old 09-09-2013, 12:16 AM   #3
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 13 ZL1, 15 Scat Pack,& 15 Silverado
Awesome numbers!
2013 M6 ZL1.. Mods- Roto-Fab CF Intake, Ported and Polish LS7 TB and Snout, 2.55" Upper Pulley, 100mm Idler Pulley, Solid Isolator, Afco Heat Exchanger with fans, ID850 fuel injectors, SW 2" LT Headers With High Flow Cats, and CMS 91 Octane tune.. 579.8rwhp and 537.4rwtq
TripleBlkZL1 is offline   Reply With Quote
Old 09-09-2013, 12:34 AM   #4
sportyb24
Romanian Outlaw
sportyb24's Avatar
Drives: 13 ZL1 , 14 Silverado Crew Cab
Wow nice on 20's for sure
[/SIGPIC]2013 Camaro ZL1 M6
sportyb24 is offline   Reply With Quote
Old 09-09-2013, 07:50 AM   #5
John Deere Racer
John Deere Racer's Avatar
Drives: 2013 zl1 m6
Nice
Congrats
2013 ZL1 M6 black on black 10 spokes
592rwhp 616rwtq bolt ons only
www.mikenorrismotorsports.com
Www.lgmotorsports.com
John Deere Racer is offline   Reply With Quote
Old 09-09-2013, 09:16 AM   #6
FUN2RUN
Banned
Drives: finding 2013
Some good track prep and 20's are the ticket.
That converter and meth are starting to pay off. Right on!
Did you spray nitrous down the whole pass?
FUN2RUN is offline   Reply With Quote
Old 09-09-2013, 11:14 AM   #7
The Baron
The Baron's Avatar
Drives: 2013 zl1
The problem with my car now is the blower.. The blower on my car is shot. I hurt it trying to find the I.a.t problem. The car only makes 13 pounds of boost now. It made 15-16 when I put it together:(. I had a 35 jet in it for the first few passes of the weekend and it was running what it used to go in motor alone.. I started creeping up fuel and jet sizes every pass on sat.. I let out between the 3-4 shifts.
Old 09-09-2013, 11:16 AM   #8
sportyb24
Romanian Outlaw
sportyb24's Avatar
Your is a manual ?
Old 09-09-2013, 01:54 PM   #9
The Baron
The Baron's Avatar
Drives: 2013 zl1
No
Old 09-09-2013, 08:40 PM   #10
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Baron - just out of curiosity - are you running stock idler pullies or aftermarket? I ask bc I am also losing boost. My shop recently put a gates fleetrunner (green) serpentine belt on a ZR1 and picked up 3lbs of boost. Apparently it is very difficult to detect blower belt slip even on a dyno. Only giveaway was a loss of the 3lbs. Im going to swap belts and go to the larger upper and small lower idlers to see if that helps (more surface area touching on the upper blower pulley)
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 09-09-2013, 08:57 PM   #11
Supercharged SS
Drives: 2010 Camaro
If you log you car at the track blower slip is clear as day. Your tuner should be able to see it on the dyno as well. It's very easy to detect. Looks at the psi on the dyno sheet. If its all over the place it's probably slipping.
Old 09-09-2013, 11:16 PM   #12
big dave
Drives: 2017 ZL1
Impressive times. What was your mph on those passes?
'17 ZL1 Jet Black A10 11.08 @ 125 stock! 1.72 60'. 4275# raceweight.
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
'99 SS M6. 13.28 @ 105 stock. 12.02 @ 116.5 bolt-ons on street tires. Full weight. New combo 10.94 @ 126.9 n/a full weight on et streets. .http://youtu.be/BCJNFJrp2lg
big dave is offline   Reply With Quote
Old 09-10-2013, 12:46 AM   #13
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
When are you gonna put a real tire on it and chase down the livernois times?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 09-10-2013, 07:56 AM   #14
Drew P
Drew P's Avatar
Drives: Camaro ZL1
@ Supercharged - Logs have been run. The PSI did NOT bounce during track or dyno runs. No belt slip noise either. I would not have believed the fix but for seeing it.
