Gen5DIY
Old 09-09-2013, 01:47 PM   #1
SargeantSarcasm
SargeantSarcasm's Avatar
Drives: 2013 ZL1 M6
Upgrades necessary with Procharger?
I'm looking to add a procharger to my 2010 manual. I'm currently making about 490 at the tired with a new cam, heads, and a full exhaust. After the procharger is it necessary to upgrade the rear end if I don't plan on launching it hard at the track and I'll mostly just be doing highway pulls?
Thanks
SargeantSarcasm is offline   Reply With Quote
Old 09-09-2013, 01:57 PM   #2
Camper
Banned
Drives: 10' 2SS LS3 M6
Fuel,driveshaft,suspension are popular.
If roll racing, I think the rear should last a bit.
what is your cam spec.
Camper is offline   Reply With Quote
Old 09-09-2013, 01:58 PM   #3
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
the better question is what power level are you trying to reach?
I personally think the rear end is fairly strong, minus the posi unit. I shredded my spider gears with 620whp but several trips to the track. That was more because of my burnout and 1 wheel peels.
I ran a 10.99 and tons of low 11 second passes at the track with completely stock rear end, trans, and suspension. Only upgrades i did were clutch(mcleod RXT) and axles(DSS1400hp), and 18" DR's.
Even after snapping my output shaft (known issues on early 2010 builds) and my posi unit... i went back to stock. But after finishing my motor build this year i plan on at least doing the JRE posi mod.. or ZL1 rear end conversion. But i will be upwards of 900-1000whp then.
xjer22x is offline   Reply With Quote
Old 09-09-2013, 05:06 PM   #4
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
The rear will be fine if not drag racing all of the time. Just put the blower on with a alky control meth it and have at it. I see you're in Baton Rouge so what shop do you deal with? If you don't have one Futral Motorsports in Walker can get it done for you.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 09-09-2013, 05:18 PM   #5
SargeantSarcasm
Drives: 2013 ZL1 M6
Thanks guys...I go to Futral now. They haven't worked on my car yet. The work was done in Florida though.
If I am gonna replace either the differential or axles which one should have priority?
Old 09-09-2013, 05:33 PM   #6
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Axles. Hands down.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-09-2013, 05:49 PM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
What cam are you running? It's definitely not boost friendly making 490.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-09-2013, 06:08 PM   #8
Camper
Banned
it may be fine for a centri/procharger. You'd be suprised as to whats boost friendly for a centri/procharger
Old 09-09-2013, 06:11 PM   #9
2SS45th
2SS45th's Avatar
No I know centri cams, the one I run is for a centri as well, but 490 is very NA oriented is all. It'll work fine, but I was just surprised by the NA number.
Old 09-09-2013, 06:24 PM   #10
SargeantSarcasm
Drives: 2013 ZL1 M6
My big issue is I'm not sure of the cam's exact specs...was already in the car when I purchased it
Old 09-09-2013, 06:26 PM   #11
2SS45th
2SS45th's Avatar
Gotcha, maybe try to figure that out if you can, it will help your tuner out.
Old 09-09-2013, 06:27 PM   #12
SargeantSarcasm
Drives: 2013 ZL1 M6
Is it possible without paying for the engine to be torn down?
Old 09-09-2013, 06:28 PM   #13
2SS45th
2SS45th's Avatar
If you can find the shop that did the work yeah, or the first owner. I wouldn't tear stuff apart to find out if I were you, it won't make a huge difference anyways.
Old 09-09-2013, 06:33 PM   #14
Chris82xx
Chris82xx's Avatar
Did you buy the car from someone on this forum? Also, what state was the car in. Some of the people on here can probably help narrow down what shop the car was at.
811RWHP/719RWTQ
