BeckyD @ James Martin Chevy
Old 09-09-2013, 08:04 PM   #15
SargeantSarcasm
SargeantSarcasm's Avatar
Drives: 2013 ZL1 M6
No it wasn't someone on the forum. I got the car shipped from Daytona beach...if it helps, the heads are stamped with the name "Hunters"
SargeantSarcasm is offline   Reply With Quote
Old 09-09-2013, 08:19 PM   #16
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Uh oh.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-09-2013, 08:38 PM   #17
SargeantSarcasm
Drives: 2013 ZL1 M6
Originally Posted by 2SS45th View Post
Uh oh.
Old 09-09-2013, 08:43 PM   #18
2SS45th
2SS45th's Avatar
HPS has quite the rep around here.
Old 09-09-2013, 08:56 PM   #19
SargeantSarcasm
Drives: 2013 ZL1 M6
I'm guessing its a bad rep??
I'm not quite sure what I'm dealing with here haha
Old 09-09-2013, 09:09 PM   #20
2SS45th
2SS45th's Avatar
HPS has been known to have some major issues, mostly with turbo kits done, but they have had quite a few motors blow up on them. They have since gone out of business because of it.
Old 09-09-2013, 09:12 PM   #21
SargeantSarcasm
Drives: 2013 ZL1 M6
Damn. Guess I should get that checked out
Old 09-09-2013, 09:18 PM   #22
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
It's nothing that can't be worked with. There are quite a few shops that have a MUCH better rep. then HPS and actually know what they're doing. Who's gonna do you ProCharger install?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-09-2013, 09:39 PM   #23
H-E
Drives: 2010 zr1 Camaro 2011 vert
I would look at axles and a clutch,keep a check on the drive shaft bolts...Ill be glad to make you a killer deal on the Street Slayer clutch and axles,just give me a call anytime
H-E is offline   Reply With Quote
Old 09-09-2013, 09:55 PM   #24
SargeantSarcasm
Drives: 2013 ZL1 M6
I was thinking Futral Motorsports
Old 09-09-2013, 10:10 PM   #25
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Futral is a no brainer.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 09-09-2013, 10:19 PM   #26
Chris82xx
Chris82xx's Avatar
Enough said. Detoxx know his shit too with that shop. If HPS had their hand in that car, it'll get worked out.
811RWHP/719RWTQ
Old 09-09-2013, 10:20 PM   #27
Craig B
Craig B's Avatar
Drives: 2013 1LE
What cam are you running? It's definitely not boost friendly making 490.
How do u figure??
Craig B is offline   Reply With Quote
Old 09-10-2013, 01:36 AM   #28
2SS45th
2SS45th's Avatar
Originally Posted by Criag B View Post
How do u figure??
Because you don't make 490 at the tire with a blower cam, that is almost dedicated NA territory right there.
