sjm autoprod
Old 09-12-2013, 11:53 AM   #15
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
Originally Posted by Badbubba View Post
Confused, if afr is 11.5 throughout the run, how can that be lean? I understand if the fuel pressure drops, the injector duty cycle would need to increase. Why wasn't this seen when you 1st had the car tuned? Or did you load a canned tune or have a different shop tune it? Surging at only light throttle sounds like something else since, I would think, the stock fuel pump should be able to keep up under light load. So, not sure if the surging would be due to fuel pressure. Quite possible surging is a tune problem and that the fuel pressure was observed to be dropping as well. 133kpa should be at idle on sct livelink2, multiply by 3 and then convert to psi. 400kpa=58psi. So 70kpa, 210kpa=30psi.
I suppose if the duty cycle of the injector is maxed out, the fuel system would be dangerously lean? Again, far from an expert here guys. I just wanted to alert some of you of the potential issues with the stock pump. My advice would be to connect with Jannetty about your specific situation if you think you "might" be running lean? The "surging" really had nothing to do with running lean as I have plenty of fuel pressure under 4K rpm, it was the initial reason that I sent Ted my data logs, which turned out to be a good thing I did!
11syn3rgy is offline   Reply With Quote
Old 09-12-2013, 12:39 PM   #16
pdiddy
Drives: 2011 2SS
I am not an expert either I am not sure that lean is the correct word but what I think OP is getting at is that his AF reading although was good and "safe" his fuel pump was maxed out so much that he was losing fuel pressure and his injector duty had to increase a lot to keep up and causing a potential unsafe situation thus causing him to go with the ZL1 set up. Me also being fairly nube to this and learning think there is more than just AF to consider when building/tuning a car and wanting to be safe presssure is just another one of these items that you should consider. Please if this is incorrect correct me I take no offence to learning and being corrected.
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 09-12-2013, 02:38 PM   #17
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Originally Posted by Criag B View Post
How much HP can the ZL1 pump handle?
Ted told me that the ZL1 pump should be able to safely handle around 650 rwhp when I asked him the other day.
Old 09-12-2013, 02:40 PM   #18
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Not exactly sure where you are getting this kpa to psi conversion from? I have attached the conversion chart the I received from Ted. 400 kpa equals 43.4 psi according to this chart.
Old 09-12-2013, 03:01 PM   #19
pdiddy
Drives: 2011 2SS
I am also a little confused on how the conversion works as the normal conversion for kpa to psi is different from above. It is what Badbubba posted if you just do math but maybe there other others factors when you deal with car fuel pressure, not sure how the above chart reads.
Old 09-12-2013, 03:17 PM   #20
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
The Chart seems to show the conversion from kpa (eg map) to psi incorporating the usual barometric pressure of open air (100kpa or 15psi or 1 bar)
Geez, I feel like a nerd now
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 09-12-2013, 08:41 PM   #21
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
What he said!!! All is I know is the chart came from Jannetty, and I know better than to question the master. HA!
Old 09-14-2013, 07:28 PM   #22
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15STI,'10Expy,'10 2SS/RS M6,'47KB1
So the chart is subtracting 1bar, 14.5 psi. Thus stating that the 58 psi is absolute pressure and not gauge pressure. I disagree that this chart is for our application. If a mechanical fuel pressure gauge is attached to the fuel rail, it displays around 60 psi iirc. I bench tested and set my fuel pressure safety switch for 45psi gauge pressure. If the chart is correct, I would never be able to activate my N2O. Or am I missing something? The chart doesn't represent your 6.5psi boost "pushing back" on the injector fuel pressure either. Just trying to understand.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 09-14-2013, 08:09 PM   #23
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
That chart is for boost reference.
Fuel pressure is different. You don't deduct 14.5 psi or 1 bar or 100 kpa from what you see.
In fuel pressure what you see is what you have. 3 bar is 43.5 psi. 4 bar is 58 psi.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is online now   Reply With Quote
Old 09-15-2013, 01:53 PM   #24
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Yep.
Old 09-15-2013, 03:14 PM   #25
NicKey
Drives: Nickey Super Camaro
Originally Posted by Ron_Robinson1 View Post
I have been over 600 rwhp for 7,000 hard miles without any issues this summer, and I don't use a ADM controller with my ZL1 pump. Car runs great.
A properly programmed ZL1 fuel pump controller / ADM is necessary to get the maximum efficiency from a ZL1 pump installed in a non ZL1 Camaro.
NicKey is offline   Reply With Quote
Old 09-16-2013, 09:10 PM   #26
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
BooSSted is offline   Reply With Quote
Old 09-16-2013, 09:24 PM   #27
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
This is what Jannetty said as well.
