Caryle Racing
Old 09-10-2013, 08:00 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
ECS kit ?
I just purchased a ECS blower kit and was wondering if my SLP 25% UDP could be used along with the supercharger pulley? Thanks.
Craig B is offline   Reply With Quote
Old 09-10-2013, 08:18 PM   #2
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Nope. ECS has the lowest pulley setting on the blower itself. Going slower will create higher IAT's and make the blower less efficient.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-10-2013, 08:23 PM   #3
Craig B
Craig B's Avatar
Drives: 2013 1LE
I'm looking to spin my just my A/C with the UDP, not the blower. I was wondering if the blower pulley would bolt to the UDP?
Old 09-10-2013, 08:27 PM   #4
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
I had one and they removed it when installing my blower. I'd say no.
VanquisherSS is offline   Reply With Quote
Old 09-10-2013, 08:52 PM   #5
Camper
Banned
Drives: 10' 2SS LS3 M6
no it will not.
Camper is offline   Reply With Quote
Old 09-10-2013, 08:54 PM   #6
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks Guys.
Old 09-10-2013, 11:44 PM   #7
BLACK10
BLACK10's Avatar
The blower pulley hub will not fit in the UD pulley. That's the real reason it will not work
Old 09-11-2013, 07:51 AM   #8
Matt @ FSP
Matt @ FSP's Avatar
Yep Nick is correct... If you have an ATI UD pulley, that can work. But the SLP/Powerbond/ASP styles will not work with the balancer hub. Good news is that if you did not save your stock balancer they are about $65 at the dealership.
Matt @ FSP is offline   Reply With Quote
Old 09-12-2013, 12:52 PM   #9
East Coast Supercharging
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
Looks like this was handled!
thanks guys!!
East Coast Supercharging is offline   Reply With Quote
Old 09-12-2013, 04:21 PM   #10
Chris82xx
Chris82xx's Avatar
We got it covered.
811RWHP/719RWTQ
