Jason 98 TA
Old 09-10-2013, 10:22 PM   #1
tmcclint
tmcclint's Avatar
Drives: 2014 AGM 2SS/RS 1LE
1LE Ground Clearance vs stock 2SS
Does any one know how much lower the 1LE is compared to a stock 2SS for the 2014 model year? I was doing my daily commute this morning and there are two spots on my commute where I saw a stock Volvo station wagon scrape the pavement. I was planning on ordering a 1LE but now I'm having second thoughts. I live in the mountains and I have a feeling this will be an issue several places around town. I'm actually pretty sure I'll have to remove the front splitter to even get close to where I need to go on my commute. If the 1LE is much lower than the stock SS then I think the 1LE is not going to work.
Any thoughts would be appreciated.
Todd
tmcclint is offline   Reply With Quote
Old 09-10-2013, 10:32 PM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Well from my experience I have not really noticed any ground clearance differences/issues compared to the 2011 2SS that I traded in for my 1LE. I'm pretty sure the suspension on the 1LE does not change the ride height, the only slight difference in ride height comes from the wheel/tire combination. The 1LE wheels/tires have an overall diameter that is a little shorter than the SS wheels.
Nick S is offline   Reply With Quote
Old 09-11-2013, 12:06 AM   #3
Mmar88
Drives: 2013 BRM 2SS/RS/1LE/NPP/NAV
Just back into parking spaces and there will be no issue
Mmar88 is offline   Reply With Quote
Old 10-06-2013, 03:01 AM   #4
Msmall143
Msmall143's Avatar
Drives: Camaro
The front splitter would negatively affect clearance going up hills. You could remove and sell If you did t like it
Msmall143 is offline   Reply With Quote
Old 10-06-2013, 09:31 AM   #5
Cool1LE
Cool1LE's Avatar
Drives: 2014 Blk 2SS/1LE
Don't let this stop you!! A 1LE is soooooo worth the money and wait. Just the look alone not to mention the performance upgrades.... the splitter can be removed if it doesn't work in your area, just be sure to try it before assuming you will have issues
Cool1LE is offline   Reply With Quote
Old 10-06-2013, 01:06 PM   #6
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
The splitter is not the low point, but you do need to be careful approaching inclines. The lowest point on mine is the exhaust brackets just behind the front wheels where there's not much more than 4.5" even though I think the official quote is 5".
bluBlud is offline   Reply With Quote
Old 10-06-2013, 01:44 PM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
A 1LE uses stock SS springs. So like the guys said it's really only the tires that drop it. The front spitter adds little to lower but extents the front and does away with that curve on the bottom of an SS's nose.
This is my first 5th Gen so I have nothing personally to compare to.
Sent from my DROID RAZR HD using Tapatalk 4
Firefighter is offline   Reply With Quote
Old 10-07-2013, 04:36 PM   #8
markgws6
markgws6's Avatar
Drives: 2013 Camaro 1SS/1LE
You don't need to install the splitter. Just tell your dealer to leave it off the car for you. Unless the factory is now installing them on the 14 models...
There are some pretty steep driveways here and it's not been a problem for me if I go up at an angle, I only scraped once. Also, I've not been up any steep mountain roads yet but if there is "any" chance of there being any snow or ice or heavy rain, do yourself a favor and get all-season tires/wheels mounted. That I'd personally be more concerned with that than the ground clearance.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
CAI intake, Apex cold air scoop and washer bottle, Hypertech 91 tune, ZR1 diff fluid, Motul RBF-600, Russell SS brake lines, SLP skip-shift override, SRP Pedals, Forza 3 way exhaust controller, octane fuse reset
markgws6 is offline   Reply With Quote
Old 10-08-2013, 04:02 PM   #9
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
Really.
I would rather have a 1LE and watch out for the front splitter than not have one.
The freakin car is so awesome for the money. Dude, buy it, love it and dont look back. JUst sayin
When you pull into spots watch the front splitter on the curbs and tire stops.
Jim
Jims Mongoose is offline   Reply With Quote
Old 03-05-2014, 11:28 AM   #10
domano 68
domano 68's Avatar
Drives: 2014 1LE
Pulling in my driveway last night in my new 1LE and heard an awful scraping noise. It sounded more metallic that plastic that was scraping. I looked under the front and saw the plastic air dam that sits back from the front with some scrapes. Didn't check the exhaust brackets. Glad I read this. I'll check those tonight when I get home.
So is it better to pull in at a sharp angle or as straight as possible on to the driveway to prevent scraping? When I pulled out of the driveway going out nose first (forward), I did not scrape at all. I am thinking maybe I should try backing in. Thoughts?
domano 68 is offline   Reply With Quote
Old 03-05-2014, 11:34 AM   #11
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
I dropped my 1LE and LOOOOVVEE the stance now. I use extreme caution on inclines and speed bumps as my exhaust is literally 3 1/2 inches from the ground. Get one dont be escared!
Current: PFADT Drop Springs/ZL1 Rock Guards/SLP Skip Shift Elim./DRAKE Bowtie Delete/ELITE Catch Can/XPEL Clear Film/CORSA ZL1 Cat Back/Z28 CAI
SWAG1LE is offline   Reply With Quote
Old 03-05-2014, 01:07 PM   #12
domano 68
domano 68's Avatar
Drives: 2014 1LE
So you are scraping but just going extremely slow in those situations?
Old 03-05-2014, 03:19 PM   #13
AAAND GO
AAAND GO's Avatar
Drives: 14 2SS 1LE RRM NPP / 90 Lumina Euro
My 1LE has a TPW of this week...once I get it I plan to back in to my driveway and pretty much every parking spot possible.
AAAND GO is offline   Reply With Quote
Old 03-05-2014, 03:33 PM   #14
whan
Drives: 2014 1SS/1LE
I scrape the underside of the front splitter occasionally but it doesn't really bother me. You can't see it and I figure it's not a very expensive part to replace if it really does get damaged.
Have scraped the exhaust though
whan is offline   Reply With Quote
1le, clearance
