Old 09-11-2013, 10:27 PM   #1
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
Kenne bell owners- advice
Before talking to a couple of the local shops I wanted to see what you guys recommend from experience.
So currently I sit on 2.8L Kenne bell (non-polished). I want to crank up the boost but not to the certain extent where I am maxing out my stock parts. Aside from the standard Kenne Bell kit I only installed a Corsa Catback and JRE Super Tensioner. So rest of the engine components are stock. What could I add to safely crank up the boost. I want to be around 520-530RWHP with 91 pump gas. Let me know your thoughts (for example; headers, cam, meth kit, smaller pulley.....)
Thanks for taking the time to help a noob, I'm learning along the way.
My stats last time checked:
466 rwhp/ 430-440 rwtq at 7.48 psi
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 09-11-2013, 10:38 PM   #2
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Your only on 91 octane? Guess that's why you had low numbers. I was over 520 on stock kb 2.8lc kit at 8psi. Have you thought about alky injection?
Also how is your IATs? I had a dual pass dual fan heat exchanger which helped a ton for the IATs. A cam will help but now your talking going into the engine. I'd say alky meth injection and a good tune.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 09-12-2013, 07:28 AM   #3
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
cam and headers will get you aound the 60hp to 80hp you want..and smaller pulley to around 9psi..
mikepage0007 is offline   Reply With Quote
Old 09-12-2013, 07:38 AM   #4
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
Your Numbers seem really low for the KB. I would definitely be getting headers, meth kit, smaller pully
meshamey is offline   Reply With Quote
Old 09-12-2013, 10:09 AM   #5
duffmobile
duffmobile's Avatar
Drives: 2010 Camaro 2SS/RS - IOM/IOM
I think I was 491 RWHP and 511 TQ with my KB and bolt ons. My car pulled timing due to heat near the upper RPMS and I either need meth or a better heat exchanger. I don't know which route to go. Love the power but this blower is a heat monster.
L99 with 2.8 LC Kenne Bell, Kooks 1 7/8 headers, Corsa Catback, R2C CAI, 491 RWHP / 500 RWTQ ---- 2010 MY #7539
duffmobile is offline   Reply With Quote
Old 09-12-2013, 10:09 AM   #6
ronniels3
I had a Kenne Bell on my C5 Corvette. I hated it. After the thing heat soaked all it was good for was frying burgers. I went back to a centrifugal.
ronniels3 is offline   Reply With Quote
Old 09-12-2013, 10:42 AM   #7
Rcfiddy1
Rcfiddy1's Avatar
Same here.
Build Thread
Old 09-12-2013, 02:40 PM   #8
lbheat
lbheat's Avatar
Yeah I actually ended buying your dual heat exchanger from another guy on camaro5 that bought it from you. I will be installing it this weekend along with the polished intake since something came up last weekend. As for alky meth kits, are there any dangers from this type of setup? I might hit up Adam from ST Motorsports for a tune, hes about 40 miles from me but he sure does make some of the best tunes for the Kenne bell's.
Kenne Bell
Old 09-12-2013, 06:40 PM   #9
Rcfiddy1
Rcfiddy1's Avatar
Congrats. That heat exchanger works great, you'll like it. Look in my build for pics of the install and wiring.
Build Thread
Old 09-12-2013, 07:32 PM   #10
ayousef
ayousef's Avatar
Drives: 2013 ZL1
who tuned your car? don't tell me this is a canned tune...
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 09-15-2013, 05:06 PM   #11
lbheat
lbheat's Avatar
ST Motorsports. It has a conservative tune on purpose as this is a daily driver, but i've decided to start cranking it up
Kenne Bell
Old 09-15-2013, 07:01 PM   #12
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
yeah...466 RWHP seems rather low for even 91 octane at around 8lbs.
KB's are notorious for high IAT's so a better Heat exchanger is mandatory although with mixed results.
Your Tuner probably did all he could safely.
My Harrop puts out well over 500 RWHP with barely 6lbs(actually 5.5) of boost but, it comes with a oversize dual pass exchanger stock,it's freaking hot in Australia .
Cool IAT's are key to good power at lower boost levels.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
kenne bell, supercharged
