JUICEDMOTORSPORTS
Old 09-11-2013, 11:54 PM   #1
driarene
driarene's Avatar
Drives: 2LS Summit White
Exclamation LED turn signal help!
so i bought these LED turn light signals from carid. a little bit ago i bought the lumen 420 bulb
http://www.carid.com/2012-chevy-cama...-10269824.html
when i got them and went to install them, part of my headlights went out.
I tried switching both of them to see if one was bad but that didn't work. I had the constant problem of at least one of my lights not working.
for example, with the LED turn signals plugged in, my right headlight and foglight would go out but the turn light signals and the left headlight and foglight would be on.
I think its probably not geting enough power or the distibution is messed up somewhere along the way. do i need some type of adapter for these to work? or maybe the led lights are too powerful?
I do have a HID conversion kit in my headlights from TRS and also a led fog light kit from phastek performance (the add fog lights to your LS kit) if that helps any
any help guys? thanx in advance!
driarene is offline   Reply With Quote
blinkers, led, led turn light signals, lumen
