HeadlightArmor
Old 09-12-2013, 10:15 PM   #1
No_Traction_B
No_Traction_B's Avatar
Drives: 2010 Camaro SS D1SC
help asap. dss install driveshaft torque spec
What is the torque spec front n rear for spacer to spindles of diff and trans
No_Traction_B is offline   Reply With Quote
Old 09-12-2013, 10:18 PM   #2
No_Traction_B
Help
Old 09-12-2013, 10:42 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
57 ft. lbs. I just installed mine a month ago. If you're still not 100%, give DSS a call in the morning,
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
