sjm autoprod
Old 09-14-2013, 08:30 PM   #1
Skoulikimou
Skoulikimou's Avatar
Drives: Camaro SS LS3 2010
Smile How much boost ?
How much boost is safe enough for ls3 engine with stock internals ,as I'm using my car as daily drive .
Currently I'm running 6 psi which I believe it's little low IMO.
Camaro 2010 2SS LS3 , Xforce 1 7/8 headers LT,Off road pipes , CAI , Custom Tune , TVS 2300
Skoulikimou is offline   Reply With Quote
Old 09-14-2013, 08:47 PM   #2
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Everybody will tell you different numbers based on a number of things. I'm currently at 15lbs, however, I would say 8-10 at most.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-14-2013, 08:58 PM   #3
Skoulikimou
I'm using 3.8 pulley which should give me 7.5 to 8 psi ,I thing I'm losing boost due the LT headers .
Old 09-14-2013, 09:02 PM   #4
Supercharged SS
Drives: 2010 Camaro
It's not the boost that'll do you in it's the lack of a fuel system.
All you'll be able to do is put a 3.6 pulley on and call it a day. Any more than that and you need fuel upgrades.
Old 09-14-2013, 09:05 PM   #5
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I have right at 10psi with a 3.4 pulley.
Old 09-14-2013, 09:06 PM   #6
Supercharged SS
Drives: 2010 Camaro
Bap?
Old 09-14-2013, 09:07 PM   #7
UF4LIFE102SS
Drives: 2010 2 SS
dual pump LPE
Old 09-14-2013, 09:08 PM   #8
Chris82xx
Chris82xx's Avatar
dual pump LPE
That'll do it.
Jamie, will running a BAP help if he wanted to run more boost on a smaller pulley?
811RWHP/719RWTQ
Old 09-14-2013, 09:13 PM   #9
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
10.5 psi here and dual pumps
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-14-2013, 09:15 PM   #10
Supercharged SS
Drives: 2010 Camaro
That'll do it.
Yes. A 3.4 will need a bap.
With the TVS any more than 10 psi in a 6 rib will generate belt slip. That blower is pretty much the biggest pain in the ass to make any decent boost.
Old 09-15-2013, 04:40 PM   #11
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
If you run meth I'd say 12 all day. No meth I'd stay around or less than 8.
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
Old 09-15-2013, 04:47 PM   #12
Supercharged SS
Drives: 2010 Camaro
That's a bad idea. You should never rely on method as a fuel supply. To many bad things can happen.
Not to mention he'll need at least the OD rear cogs to make 12 psi.
Old 09-15-2013, 04:53 PM   #13
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
It's not even about boost that matter to a motor, it's dynamic compression, cylinder pressure. Anything over 650whp is on borrowed time.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-15-2013, 05:19 PM   #14
sprayedv
I've been using meth on all my cars for years now with not 1 problem.
Of course if you go cheap end and buy the basic snow performance kit and your pump craps out you're going to have a problem. But if you buy the good meth kits you'll never see that happen.
Meth is God's gift for people who don't have access to good fuel and/or E85. It's cooling effects are also pretty ba. My spray is a much better coolant but who sprays all day .
camaro ls3 boost supercharger
