Flowmaster Exhaust
Old 09-15-2013, 05:23 PM   #29
Supercharged SS
Drives: 2010 Camaro
Originally Posted by sprayedv View Post
I've been using meth on all my cars for years now with not 1 problem.
Of course if you go cheap end and buy the basic snow performance kit and your pump craps out you're going to have a problem. But if you buy the good meth kits you'll never see that happen.
Meth is God's gift for people who don't have access to good fuel and/or E85. It's cooling effects are also pretty ba. My spray is a much better coolant but who sprays all day .
So you haven't add any meth problems so that must mean every meth system ever made will function perfectly forever....... Wow.
Old 09-15-2013, 05:23 PM   #30
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Originally Posted by Supercharged SS View Post
Admitting your wrong is the first step in recovery. Are you ready to take that? Or are you still thinking your are the smartest man walking the face if this earth. I hope you don't tune cars for a living.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-15-2013, 05:25 PM   #31
Supercharged SS
Drives: 2010 Camaro
Originally Posted by 2SS45th View Post
BTW, my car was built also.... I just payed someone else to do it!
Old 09-15-2013, 05:26 PM   #32
2SS45th
2SS45th's Avatar
Hey, at least you didn't buy an HPE car or the like!
Old 09-15-2013, 05:42 PM   #33
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
He went bye bye!
Old 09-15-2013, 06:45 PM   #34
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Twice, you forgot to mention you had it built twice. Just reminding you.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-15-2013, 06:56 PM   #35
2SS45th
2SS45th's Avatar
Old 09-15-2013, 07:09 PM   #36
Supercharged SS
Drives: 2010 Camaro
It's only money.... I can just go get some more.
Old 09-15-2013, 07:25 PM   #37
Chris82xx
Chris82xx's Avatar
Then I think you should send some my way.
811RWHP/719RWTQ
Old 09-15-2013, 07:27 PM   #38
Supercharged SS
Drives: 2010 Camaro
Get in line like everyone else!! I'm just going to spoil the shit out of my son. Like ridiculously. That is, if he ever decides he wants to be born.
Old 09-15-2013, 07:30 PM   #39
Chris82xx
Chris82xx's Avatar
No. Typically, the first child is late. Happened with both my first children.
811RWHP/719RWTQ
Old 09-15-2013, 07:39 PM   #40
Supercharged SS
Drives: 2010 Camaro
7 days left and counting....
Old 09-15-2013, 07:42 PM   #41
Chris82xx
Chris82xx's Avatar
7 days hopefully, then hours of labor of which you will gladly pay for, and then days in the hospital of which you will probably be sleeping.
811RWHP/719RWTQ
Old 09-15-2013, 08:01 PM   #42
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
And then when you have hiccup with the meth system you can kiss that engine could by.
It's ok for you to learn something here. We welcome trolls.
Well I've had my "meth" car up and running with spray and boost.
Didn't yours blow up?
I can understand you don't like meth but it's not a "bad" system at all. People who say its bad either hear its bad or have gone on the cheap side. I can name you about 15 other cars in my area who have been running meth for 2+ years with no problem. Same pump and all.
Nitrous blows cars up does that mean its bad? It has components that can fail and cause catastrophic engine failure... Does that mean spray is bad?
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
camaro ls3 boost supercharger
