BORLA
Old 09-15-2013, 11:40 PM   #1
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
Dyno'd.....finally!
Well I finally got my car to a dyno to see what it would do with the mods I have. Sorry, no baseline and I'm still waiting to get the printout emailed to me so I can post and see the full numbers. 9.55" crank pulley, air raid cai, FAST 85lb injectors and tsp 2" long tubes w/offroad pipes...put down 632rwhp. Still haven't got my 2.5" upper pulley on and they tried a ported ls3 tb but it freaked out my cars comp and went into reduced engine power so it was pulled back off. Hopefully I'll get the sheet soon to post. Just thought I'd share my results with y'all.
2013 AGM m6 zl1-airaid cai, 9.55" crank pulley and jre tuning, 2" tsp longtubes, FAST 85lb injectors...630/627
Nemisis is offline   Reply With Quote
Old 09-15-2013, 11:41 PM   #2
Congrats
Old 09-15-2013, 11:54 PM   #3
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
nice number with the 9.55.
Azzkker is offline   Reply With Quote
Old 09-15-2013, 11:57 PM   #4
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Congrats, where did it get done at?
danvillekidd is offline   Reply With Quote
Old 09-16-2013, 12:01 AM   #5
Nemisis
Installed everything myself except for injectors, had Ivan at southwest speed in albq, nm do those and the extra tuning it needed.
Old 09-16-2013, 12:09 AM   #6
Nemisis
Curious though, has anyone had probs installing ported tb on their cars yet? It threw code p1516 and couldn't get around it.
Old 09-16-2013, 09:02 PM   #7
Azzkker
Azzkker's Avatar
several have installed ls3 90mm TB on their cars, but most seem to do the v-max ported 87mm lsa TB.
I am not a big fan of the ls3 install due to the required reversal of the TB to clear the supercharger drive. This in turn changes the way the TB blade opens, which in theory could affect the drivability of the car.
Old 09-16-2013, 09:04 PM   #8
Nemisis
Well, curiously enough took it to the dealer and they found a prob....even storing a car in a garage and brand new house you could get rodents. Dealer found that a mouse/rat chewed part of the wiring harness for the tb causing the code:-/
Old 09-17-2013, 10:38 AM   #9
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I have had more tuning issues from throttle body codes than any other. I don't tune anything myself, I bring it in to ADM and he adjusts it. I think you would be better off staying with a stock throttle body as long as possible unless your particular tuner has a lot of data on other throttle bodies in the supercharged engine. The stock one will easily support 700 whp. Plus there have been some issues with position calibration when they get ported.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 09-25-2013, 04:18 AM   #10
jashobbsie
Davenport Stage 5+
jashobbsie's Avatar
Drives: Camaro ZL1 & C7 Corvette 3LT Z51
lets see the print out of the dyne..those #'s seem high for those mods... just saying
Davenport Motorsports stage 5+ 2013 ZL1 Camaro
Victory Red Auto
jashobbsie is offline   Reply With Quote
Old 09-25-2013, 06:57 PM   #11
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
I opted for the regular 90MM TB, didn't go ported although I know several people who have run a similar mod setup as you and gone ported 90MM TB with no issues.
Those power figures are pretty impressive for just LT's and a 9.55 lower, was that on a DYNOJET?
I don't know if I'd throw a 9.55 lower and 2.5 upper at the same time without swapping the stock cam out, that's a lot of boost for a stock cam
My Toys:
2012 ZL1 Coupe (M6) #80
2012 Nissan Titan
2007 Ducati 1098
2006 Yamaha R6 (Track/Race Only )
IcePick06 is offline   Reply With Quote
Old 09-26-2013, 03:59 PM   #12
mylftft
mylftft's Avatar
Drives: 2013 TT ZL1
Some shops always seem to get very high hp numbers
I'm sure the car is alot of fun to drive, congratulations.
mylftft is offline   Reply With Quote
Old 09-26-2013, 09:28 PM   #13
Nemisis
The numbers I found out were 630/627, I have the dyno graph but have had trouble posting. The mods are airaid cai, 9.55" lower and tsp 2" long tubes with offroad pipes plus tuning. Doesn't seem unusual to me. I can email if someone else wants to post it for me???
Old 09-26-2013, 09:29 PM   #14
Nemisis
Say a typical M6 puts down 500ish then 100+ rwhp for 4-5 extra lbs of boost, headers, tuning and cai.
