Gen5DIY
Old 09-16-2013, 10:29 AM   #1
mropus
mropus's Avatar
Drives: 2010 black 2ssrs
engine stops
wasnt sure where to put this but since the car is supercharged ....here we go. my car runs extremely well, driveability is excellent but here recently ive had a small problem with the car dying after running for a long time around 2000 rpm and then pushing in the clutch, the rpms drop and the car dies. this rpm drop has always happened but the car hasnt died the way it does randomly now. i have cleaned the maf sensor and it still didnt help.....any ideas?
Mr. Opus
mropus is offline   Reply With Quote
Old 09-16-2013, 10:50 AM   #2
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
Who tuned your car?
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
Old 09-16-2013, 01:18 PM   #3
mropus
mropus's Avatar
Lane Culver.....im resistant to think its in the tune as it has only started this recently....couple of weeks ...the last tune was over a year ago
Mr. Opus
Old 09-16-2013, 01:26 PM   #4
Camper
Banned
Drives: 10' 2SS LS3 M6
vacuum leak?
Camper is offline   Reply With Quote
Old 09-16-2013, 02:15 PM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I'm with Camper, sounds like a vacuum leak possibly. It kinda sounds more like the symptoms when a cam is searching for idle, but it wouldn't be that at this point. Was there a tune update recently? Maybe the idle was set too low?
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-16-2013, 02:56 PM   #6
mropus
mropus's Avatar
idle normally runs around 800....ill check to see if i can find any vacuum leaks, but i thought that would have thrown a c.e.l.
Mr. Opus
Old 09-16-2013, 03:46 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
What blower system are you running and what fuel mods do you have done. I'm partial to think that there might be something wrong in that area.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-16-2013, 03:51 PM   #8
2SS45th
2SS45th's Avatar
Have you pulled the codes?
Old 09-16-2013, 03:52 PM   #9
Chris82xx
Chris82xx's Avatar
If his CEL isn't on, would he be throwing any codes?
811RWHP/719RWTQ
Old 09-16-2013, 04:09 PM   #10
2SS45th
2SS45th's Avatar
Yeah, the tune can stop the lights from coming on even when the code is present, all depends on how the tuner set it all up.
Old 09-16-2013, 04:16 PM   #11
Camper
Banned
I pointed to a vacuum leak due to him saying it came on recently.
Old 09-16-2013, 04:41 PM   #12
2SS45th
2SS45th's Avatar
Yes, but it seems like it has been searching for idle for some time now, at least it sounds that way...
Old 09-16-2013, 10:18 PM   #13
mropus
mropus's Avatar
maggie 2300 id850 injectors kb boost a pump....most recent mod was mcleod rxt twin disc clutch.....only does this when it has been running at 2000 rpm for a while then push the clutch in and rpms drop out....car starts back immediately with no difficulty starting
Mr. Opus
Old 09-16-2013, 11:13 PM   #14
ayousef
ayousef's Avatar
Drives: 2013 ZL1
my car did the exact same thing when I fiddled with the deceleration fuel cutoff parameters, try disabling deceleration fuel cutoff if you cannot find another cause, and if that does help look at clutch fuel cut off, I would bet your problem is somewhere between those.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
