JDP Motorsports
Old 09-17-2013, 04:09 PM   #15
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Ted is right about the addition of a 2.55 upper - the IAT2s skyrocket and the amount of timing you need to pull makes the gains negligible unless you are driving on race gas. I have attempted multiple pulley combinations and found this to be true. I am working with D3PE to try to construct a revised intercooler - but as of yet it has not happened. If anyone knows of a company building intercoolers (not HX) for a ZL1 let me know.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 09-17-2013, 04:20 PM   #16
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
The stock fuel pump up to this?
hairtrigger is offline   Reply With Quote
Old 09-17-2013, 04:37 PM   #17
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Yes fuel pressure holds solid.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 09-17-2013, 04:43 PM   #18
JANNETTYRACING
We have done a lot with PD blowers and found that the Heat exchanger and tank do nothing to improve IAT, because the Intercooler inside the blower is just simply taxed at higher air flow.
So your on the right track, you need a larger intercooler Inside the Blower.
We even run Ice water through them and still get the same rise in temp 90 Degrees in a 10 second run, whether we start at 100 or 32 degrees
With Ice water, the only advantage is starting and finishing lower.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-17-2013, 06:14 PM   #19
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I need this upgrade so bad. If only I was not poor.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 09-17-2013, 08:43 PM   #20
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
Want!!
Very nice!!!
swizlstik is offline   Reply With Quote
Old 09-17-2013, 08:56 PM   #21
crg
Drives: '68 Camaro SS, '74 Corvette
Ted, I know HP numbers will vary with different mods, but what would be the HP limit of a 90mm throttle body before one would need to go to a 102mm?
crg is offline   Reply With Quote
Old 09-17-2013, 10:09 PM   #22
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28, Challenger
Ted.
I agree with you Ted, that's why I see no real advantage to run a bigger tank unless we can cool it. I have always said just putting on a bigger tank will not do much.
Skylane765 is offline   Reply With Quote
Old 09-17-2013, 10:53 PM   #23
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
My money is on less than 16 degrees.
16 deg with a 9.55 pulley and 93 octane is what I was able to run. With half and half 104 octane and 93 octane I ran 20.5 deg advance and picked up another 5 mph in the 1/4.
Ted, I was just curious average above 4000 rpm how much timing it could tolerate. I know it varies with RPM but where do you max out?
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 09-17-2013, 11:05 PM   #24
blk13
Drives: 2013 zl1
Was this with or with out cats? whats the horsepower difference if I was to run the cats with these headers.
blk13 is offline   Reply With Quote
Old 09-18-2013, 09:05 AM   #25
JANNETTYRACING
It is Unlikely you will max out a 90mm TB with this 1900 blower.
In my experience a tank under the hood just collects Heat, that is why GM opted out of a tank.
Boost Loves Octane.
I hate to quote timing numbers because people will take it as gospel and every combination is unique, and I don't want anyone hurting they're engines on what I said.
I suggest you continue to test what works best for your combination.
This was With Cats, I don't expect any Power difference without them.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-18-2013, 10:04 AM   #26
Performance Enthusiast
Drives: Domestic
Are the ID-850 injectors required for the 18% over drive crank pulley?
It is my understanding that the stock injectors will work with a 9.17" pulley.
Performance Enthusiast is offline   Reply With Quote
Old 09-18-2013, 10:11 AM   #27
JANNETTYRACING
Yes they are.
The Stock injectors will have enough fuel if you shut off Cat over temp fueling but are on the ragged edge at that.
If you try and run with Cat over temp fueling on Forget it.
You can toast a set of Cats Pretty easy without the larger injectors.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2013, 01:49 AM   #28
Skylane765
Skylane765's Avatar
Ted.
Yes, Ted did all the work, if you need all the tuning numbers then that should be up to the owner to test and see what they get.
