BeckyD@RodgersChevrolet
Old 09-16-2013, 07:24 PM   #1
sycraft
COTW 5/06/2013
sycraft's Avatar
Evap System for Boosted V6- Mine
I am starting a thread to explain what I am having built to handle the evacuation on my IPF supercharger. Right now in stock trim, both valve covers are vented to a catch can and the can is vented to the supercharger inlet, there is no suction or fresh air entering from the intake, it is plugged. This is what I am going to change:
I am going to leave the IPF can where it is and route the the fresh air inlet through that can to the supercharger inlet, air will be able to enter the system through the passenger side valve cover of the engine freely. The oriface will be drilled out to increase flow rate from the 3/8" line. The catch can here is not really needed but since it is there , will keep it. The custom catch can from Mightymouse will feature a releif valve on top of the can to relieve pressure if needed and draw air through the pcv system from drivers side valve cover 1/2" line through the can to the top of the intake which is a 3/8" line, this will have a check valve to shut off back flow under boost condition. When in boost condition, the engine can breath through both valve covers and not pressurize the system. I am also having a breather for the oil cap made that will also incorporate a one way vent out to relieve pressure. All air entering the engine will remain metered. This should allow fresh air to reduce contaminents and keep the engine in proper ventalation.
Any other thoughts on this is welcomed, but I have tried a 3 way FI can and that did not do well on this setup. The currect system works, brown sludgy and wet residue upon draining, just looking for addl. decontamination.
Old 09-16-2013, 07:35 PM   #2
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Funny you mention MightyMouse been looking at his cans on other sites the only problem is the depth of his can but other than that he's been given a lot of good reviews for his cc.
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 09-16-2013, 07:36 PM   #3
sycraft
COTW 5/06/2013
sycraft's Avatar
what up with the depth?
Old 09-16-2013, 07:41 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
How to explain the depth from which blow by fills the can is lacking. For those with high blow by be prepared to check daily. The bottom hose connection is about a 1 1/2
or so from the bottom of the can.
Old 09-16-2013, 07:46 PM   #5
sycraft
COTW 5/06/2013
sycraft's Avatar
I discussed that with him today, and we are going to locate the lower port a little higher, it still draws through the top, so the bottom is no big deal. it should not push any liquid back as the check valve and vent should prevent this.
Old 09-16-2013, 07:46 PM   #6
hunterv6
Always bet on Black
hunterv6's Avatar
Here a picture of the depth
Old 09-16-2013, 07:48 PM   #7
hunterv6
Always bet on Black
hunterv6's Avatar
Kool keep us posted. Other than that like I said it a nice cc
Old 09-17-2013, 12:51 PM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
How about some pics. Do plan on mounting installing any gauges to see how good its working?
Old 09-17-2013, 08:53 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Didn't I see a much bigger version of that on Breaking Bad?
That's prettier than anything else under my hood!!
Old 09-18-2013, 08:34 AM   #10
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I guess I'm still a little confuse on the routing of the fresh air intake to the system. It's coming in through the passenger side from the catch can ? Isn't that still bypassing the MAF and entering the system ? I guess my little mind is stumped by this without a schematic. (engineers can be so dumb without writing it down).
Would love to see a fresh air intake !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 09-18-2013, 12:07 PM   #11
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Looking forward to your results.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 09-18-2013, 12:15 PM   #12
sycraft
COTW 5/06/2013
sycraft's Avatar
All ordered and being built
Old 09-18-2013, 04:38 PM   #13
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I want to see the mounting bracket, chrome, white, orange? Haha
Old 09-18-2013, 04:48 PM   #14
sycraft
COTW 5/06/2013
sycraft's Avatar
Thats the challenge. I will be fabbing the bracket
