Old 09-25-2013, 02:47 PM   #29
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Or tap in a vacuum pump sucking through a catch can. another rx idea?
Old 10-02-2013, 08:38 PM   #30
sycraft
COTW 5/06/2013
sycraft's Avatar
Back on topic: I received the can and breather today, nice stuff. Locating a place to mount it. On the front fits best. will post pics mounted and plumbed when done. I have to get some hose to finish. there is no way to overpressurize the system as the oil breather and can have a great bypass to let out pressure. there is a quality one way boost valve in the can too. more later
Old 10-03-2013, 09:54 AM   #31
sycraft
COTW 5/06/2013
sycraft's Avatar
some pics of the install, will drive and see how it performs... the breather and the can have a one way valve venting pressure, no unmetered air entering system...
Old 10-03-2013, 10:48 AM   #32
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
I like my wrinkle black should be here soon.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-03-2013, 10:57 AM   #33
sycraft
COTW 5/06/2013
sycraft's Avatar
You getting the mm setup?
Old 10-03-2013, 11:02 AM   #34
hunterv6
Always bet on Black
hunterv6's Avatar
Yea
Sent from my iPad2 on space mountain
Old 10-03-2013, 01:58 PM   #35
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Very cool. Does this breather work with the existing CC in the IPF kit.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 10-03-2013, 04:34 PM   #36
sycraft
COTW 5/06/2013
sycraft's Avatar
Yes it will , it vents only, no fresh coming in. My system uses the IPF can as a inlet can only, fresh air enters through that can and will catch moisture coming in or out freeley, the new can is all about the intake, it draws from the intake manifold, there is a check valve to prevent backflow and pulls air through the motor. there is no way to pressurize the engine and it now breathes.....
Old 10-05-2013, 08:35 PM   #37
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
OK, I'm confused. Are we thinking the IPF system alone is less than adequate?
What are the potential benefits of additional cans?
Old 10-05-2013, 08:39 PM   #38
sycraft
COTW 5/06/2013
sycraft's Avatar
I can never leave anything alone, the IPF system does a great job venting, but offers no real fresh air circulation, that's why I changed mine up. I will say that some of my idle issues and occasional stalling have been reduced because of this setup. It feels "smoother" overall. Perhaps the added air entering the intake under vacuum helps the engine idle better. All the incoming air is metered and there is no way to overpressurize the system.
Old 10-05-2013, 08:43 PM   #39
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Like the clarification Clint, might just add this to my list of things to get..which is a long list
Lil' Nasty is offline   Reply With Quote
Old 10-05-2013, 08:53 PM   #40
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Liken this a lot !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 10-06-2013, 09:01 AM   #41
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
For whatever reason, it would help me if I could see the layout scribbled on the back of a napkin to follow what and where everything is.
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-06-2013, 09:07 AM   #42
sycraft
COTW 5/06/2013
sycraft's Avatar
John B.
here
