Gen5DIY
Old 09-17-2013, 02:26 AM   #1
Rigzo510
Drives: 2012 Camaro Ls3
Exclamation Oracle halo/fog wiring help!
Before anybody tells me to use the search button I've already tried that and nobody wants the same uses as me lol.
I just received my red plasma halos/fogs today but am confused on how to wire these. These will be mostly for carshows so I need a power source that'll stay on without the keys in it or the DRL's or factory halos on so I don't know what to tap into. I still would also like to be able to turn them on if I drive.
Dynatech LT headers/Hi-flow cats/Jannetty rough idle blower cam/Full BMR suspension/3" magnaflow catback 442rwhp-410rwtq
Rigzo510 is offline   Reply With Quote
Old 09-17-2013, 02:37 AM   #2
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Sounds easy enough. Ground + wire to positive battery and put a switch in so you can turn on whenever.
Knockoutpie is offline   Reply With Quote
Old 09-17-2013, 12:18 PM   #3
Rigzo510
would I need a fuse on it or wire it direct?
Old 09-17-2013, 01:18 PM   #4
Knockoutpie
The only time you need fuses is to be safe. You don't ever really need a fuse, but if you get a surge you're ****ed on those lights. I say to with a fuse.
It's really quite a simple mod. I assume you put them in normally with the harness they give you. Theres probably a black and red wire. Black ground red is power +, hook it up normal. Then to have them on you run a wire from the + post on the battery and tap it to the main wire for your fog lights power. In the wire you will have a fuse, and then a switch. So you can turn it on or off. I mean I may be wrong though but it sounds easy.
Old 09-20-2013, 06:58 AM   #5
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Always always always use a fuse if coming straight off the battery. Preferably around 18 inches from tje battery
DraggnFrameGMC is offline   Reply With Quote
Old 09-20-2013, 07:39 AM   #6
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
I have the halo's with the remote box. I have a fuse between my battery & switch. For same reason to cut on at shows. Inline fuse to protect your lights & car.
Sent from my SPH-L710 using Tapatalk 2
CruznSS is offline   Reply With Quote
aac, halo wiring, halos, oracle halo
