Solo Performance
Old 09-19-2013, 03:49 PM   #15
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
this oddly looks identical to the elite catch can with a slightly different bracket.
When do we get the details of the inner workings?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-19-2013, 03:52 PM   #16
Leviser
Drives: 03 BLK SSS, 13 BRM ZL1.
Can the interior of the can be disassembled for cleaning? Also is there a baffle mesh inside the can? Curious on the internals? Is it possible to have a straight connector rather than the right angle which is on the side of the can? This way to have both top and side hose connectors facing towards the firewall. I have been on the fence between getting the elite, moroso and mishimoto baffled can, But this looks more factory to me than anything else I have seen and I like the looks! Thanks
Leviser is offline   Reply With Quote
Old 09-19-2013, 04:01 PM   #17
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
It is a billet aluminum can with a screw off bottom like the Elite but that is where the similarities end. Below is a side-by-side exterior comparison. Next week we will post detailed information about how the can functions and it's features.
Old 09-19-2013, 04:09 PM   #18
Apex Motorsports
Yes, it can be completely disassembled. It does have a filtration chamber with stainless steel media and multiple internal baffles. The can has three outlet ports so it can be configured however you need it, single outlet or dual, and using whichever outlet ports work best for your set up. Jeremy could reconfigure his to use one of the side ports so that the 90 degree fitting would be facing the firewall. Hex head screw in caps are included so that you can cap off the unused ports.
I guess you managed to get some details out of me.
Old 09-19-2013, 04:15 PM   #19
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
That looks very nice, I could live with that. So tempting to finally order a catch can. Braided lines as an option?
ZL1-V is offline   Reply With Quote
Old 09-19-2013, 04:28 PM   #20
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Is there an F.I specific can? Looking to replace my cans from that "other" company.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-19-2013, 04:29 PM   #21
2011Black2SS
Drives: 2017 ZL1 M6
I will be switching the side hose around this weekend to see if I like it any better facing towards the firewall.
2017 Nightfall Gray Metallic ZL1 M6
2014 Black GMC Serria Z71
1996 Red Z28
2011Black2SS is offline   Reply With Quote
Old 09-19-2013, 04:47 PM   #22
Leviser
Thank you 2011Black2SS and Apex Chase. I sent an email through apex motor sports a few minutes ago for price info.
Old 09-19-2013, 05:37 PM   #23
Apex Motorsports
One of the unique features of our catch can is that it has three outlet ports so it can be configured however you need it. All hardware needed for a single outlet install is included and you will have the option to add an extra outlet fitting for FI applications that require it. Hex head plugs are also includes to cap off any outlets not in use.
You are very welcome. You should have a response shortly.
Old 09-20-2013, 12:42 PM   #24
Ject
aka Patrick
Ject's Avatar
Thanks, Look forward to the detailed information
Old 09-20-2013, 02:09 PM   #25
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
I assume your can has had vacuum leaks out of the check valve fittings on top of the can? I had non stop vacuum leaks and no amount of Teflon tape would hold a vacuum. I even added O-rings to the valves before screwing them back in, but they still were leaking, but were much better. I ended up sealing them a urethane adhesive which has worked.
But I like the design of this can apex have presented. Might have to switch after my wallet recuperates.
Azzkker is offline   Reply With Quote
Old 09-20-2013, 03:05 PM   #26
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
Dang, missed the braided lines option
cybercoaster is offline   Reply With Quote
Old 09-20-2013, 05:00 PM   #27
2011Black2SS
Drives: 2017 ZL1 M6
Looks like you can order the catch cans now through Apex's website.
Apex Motorsports Catch Can
1996 Red Z28
Old 09-20-2013, 05:29 PM   #28
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
Should be available as a separate item soon. Will be in "kit" form, specific for ZL1, SS (LS3 or L99), etc. Probably sometime next week.
Apex Paul is offline   Reply With Quote
