Old 09-18-2013, 11:38 PM   #1
V6Camaro2013
V6Camaro2013's Avatar
Drives: 2013 V6 Camaro LT
V6 Camaro 2013 LT Borla: Headers, Cat-Back, Mufflers, Tuning?
I own a V6 Camaro 2013, and I'm planning to upgrade all the exhaust system on my car. My GM dealer recommended me Borla. At the time, I don't have enough money to buy all the package and apply the tuning.
I was planning to begin with Borla's Shorty Headers and Borla's Exhuast Mufflers (probably with dual tips) but, how I mentioned, I'm short in money and at the time I can't afford to pay the tuning. After installing these two parts, i was planning to gather some money, install the Cat-Back tubing, and then go for the tuning.
So I need opinions!!!
Installing Shorty Headers and Exhaust Muffles to my Camaro will really need the tuning (or also called chip reprogrammation)? What are the odds?
V6Camaro2013 is offline   Reply With Quote
Old 09-18-2013, 11:45 PM   #2
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
IF you could install headers you might need a tune.
But you can't, so that will save you some money right there. The 2012 and newer V6 Camaros come with a revised engine, code named LFX. The exhaust manifolds are integrated into the block, which means no aftermarket headers.
See here: http://www.camaro5.com/forums/showthread.php?t=306766
You may want to post your questions in the LFX section instead of the LLT section.
You shouldn't need a tune for an axle-back exhaust system (essentially changing the mufflers/tips), and probably not for a catback system, either, although eventually after you do whatever other mods you plan to do (cold air intake, ported throttle body, etc.) you may want to tune the car to get the most out of your mods.
Remember, tuning voids your powertrain warranty.
PS--Get a catch can on there as soon as you can afford to. A little searching of this forum will explain things further for you.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 09-19-2013, 12:53 PM   #3
Airmaster
Go Gators!
Airmaster's Avatar
Drives: '13 Camaro '12 Abarth '97 Wrangler
You have an LFX engine, you may want to look into that forum section instead. There are some minor differences. You already have headers from the factory, all you need is the catback you like and possibly some SOLO high flow cats.
You don't need a tune with just an exhaust. It does more for sound than anything else. You may get a few ponies, specifically if you have the high flow cats as well. But no tune is required.
Good luck!
Airmaster is offline   Reply With Quote
Old 09-20-2013, 08:56 AM   #4
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
Originally Posted by Airmaster View Post
... You already have headers from the factory...
Good luck!
LFX definitely doesn't have headers from the factory. Just a single exhaust port that is supposed to flow a bit more freely, which is what you're referring to, but they are not headers. Not dogging on the LFX as I'd rather have it than my LLT, but you'll never be able to get the same type of rumble out of the LFX as an LLT with true headers.
Old 09-20-2013, 03:13 PM   #5
Airmaster
Go Gators!
Airmaster's Avatar
Touche.
You are correct, but I like to gloat about my LFX :P, and it's easier to say headers than "a combined channeled path from the exhaust ports to your cats..." lol
borla, exhaust, shorty headers, tuning, v6 lt
