SDTW Custom Wheels & Tires
Old 07-24-2009, 08:48 PM   #15
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Originally Posted by 2SSRS View Post
So i did it in less than 1 1/2 hour had to get a hose clamp and a rubber plug for the brake master cylinder and 2 self tapping metal screws for the new reservoir.
looks good, might do this.
Whats the part number?
gotpball44 is offline   Reply With Quote
Old 07-24-2009, 09:40 PM   #16
Kenny
Kenny's Avatar
Drives: 2010 SS RS IOM M6
Delivered July 30 2009
Kenny is offline   Reply With Quote
Old 07-24-2009, 09:57 PM   #17
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
What do you think of the fix?.
Old 07-24-2009, 10:53 PM   #18
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
looks good i was going to do the same thing when i get my car i was going to use the resevoir off of a c6 vet since i have a friend that has vett parts out the wazoo (he sells vet parts and rebuilds wrecked/burnt vetts)
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 07-24-2009, 11:02 PM   #19
2SSRS@Gen5diy
We looked at C6 and G8 put the problem with them is that you can not buy the reservoir by its self only with the Clutch master cylinder.
Old 07-25-2009, 08:22 PM   #20
2SSRS@Gen5diy
So after doing this to my car i test drove it to Las Vegas and back home that was 260 Mi and no more leak on top of the Brake Fluid reservoir so i think that i fixed it.
Old 07-26-2009, 12:30 PM   #21
2SSRS@Gen5diy
I started a new thread and put all the info on it in post # 13
http://www.camaro5.com/forums/showthread.php?t=34085
Old 01-02-2012, 10:18 PM   #22
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
Bump. Any more info on a fix for the reservoir/cap itself?? I'm sure there are others like me that just want the problem fixed instead of having to install a 2nd reservoir. It sounds like replacing the OE cap with another OE cap doesn't work either. :(
1BADLS3 is offline   Reply With Quote
Old 01-05-2012, 11:00 AM   #23
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
My second cap is leaking too and I have the manual tranny... does anyone with the A6 have the leaking reservoir problem?
Old 01-05-2012, 11:25 AM   #24
2SSRS@Gen5diy
Here is the way i see this, When GM mixed the reservoir's what they for got is that on the clutch side we move the pedal faster then the brake's side, that makes the fluid return faster then the brake fluid, With them using a cap made for a brake reservoir that is made to be open to the air that is why it leak's, the clutch reservoir is a thread on cap so its made to keep Fluid in.
Old 01-05-2012, 11:31 AM   #25
SM0KE
IN THE CIRCLE
SM0KE's Avatar
Drives: 2010 IOM 2SS/RS
The automobile is over 100 years old. I dont understand how simple things like this get overlooked
Increasing Circle Size is not important.
Worthiness will knock at the door on it's own accord
SM0KE is online now   Reply With Quote
Old 01-05-2012, 11:34 AM   #26
2SSRS@Gen5diy
Its to save $ that is all, Buy now they saved 1M or more on this 1 part.
Old 01-05-2012, 03:56 PM   #27
clg_98ta
clg_98ta's Avatar
Not so sure if they're constantly replacing caps and reservoirs under warranty...
Old 04-02-2012, 10:06 PM   #28
v8
v8's Avatar
Drives: GT500 and 14 ZL1
I think I will do this mod, it sounds good, it can't hurt
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Can't Decide - Auto or Manual attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 209 01-04-2010 11:14 PM
Passenger Side Air Leak or Side Mirror? Icntdrv55 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 10-21-2009 10:22 PM
GM looking into Volt pictures leak Mr. Wyndham General Automotive + Other Cars Discussion 3 09-10-2008 12:10 AM
Mystery fluid 96CAMaro 4th Generation Camaros 6 07-30-2008 07:03 AM
