Old 09-20-2013, 11:46 AM   #1
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
2014 SS/1LE steering binds in turns.
want to see if any of you guys have this issue as well ...
when coming into a right turn, downshift from 3rd to second, non aggressive but not lugging, go to turn the wheel to the right and it feels like it binds up. it will fight me for the first part of the turn then free up. Like i lose all assist then it comes in. i looked and can't find anything thats rubbing.
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 09-20-2013, 12:14 PM   #2
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
I havent felt anything like that
-RPM custom cam, Kooks Headers W/ Cats, CAI Intake, Dewitt's radiator, Mocal 44 row oil cooler
-Z/28 Coilovers and Swaybars, BMR trailing arms, JPSS radius rod inserts
-C7 Z06 Front Brakes, Stainless Brake Lines, Quantum Ducts
-Z/28 Splitter, Underbody Panel, Spoiler and grille
AGM 1LE is offline   Reply With Quote
Old 09-20-2013, 12:19 PM   #3
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
That is not normal.
christianmotox is offline   Reply With Quote
Old 09-20-2013, 12:21 PM   #4
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Only thing I have felt was a pulse when turning at slow speeds... but that was only during the break in.
You need a trip to the dealer for service.
tramtwo is offline   Reply With Quote
Old 09-20-2013, 04:01 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Hmm...
Old 09-20-2013, 05:13 PM   #6
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Hmm's make me nervous
Old 09-21-2013, 01:07 AM   #7
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Its just Pete thinking....
Sent from my DROID RAZR using Tapatalk 2
Old 09-27-2013, 12:05 AM   #8
JusticePete
I have checked around with my GM Dealers and came up pretty empty. The only two things I can suggest is that you make sure the cable connections are secure and to stop by your Chevy Dealer to check for codes with a scan tool.
Old 09-27-2013, 12:16 AM   #9
Demon Z/28
Scarecrow
Demon Z/28's Avatar
I looked again and found some 2" TSP's too close to the shaft. apparently the engine moves when coming into a turn.
Old 09-27-2013, 12:19 AM   #10
JusticePete
That will do it every time.
Old 09-27-2013, 01:03 AM   #11
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Wow... good find!
Old 09-27-2013, 09:04 AM   #12
JusticePete
Originally Posted by tramtwo View Post
Wow... good find!
More than one brand has similar issues. Always pay close attention to clearance between the steering shaft, knuckle and headers.
Old 09-27-2013, 11:41 AM   #13
Demon Z/28
Scarecrow
Demon Z/28's Avatar
I need to pull the shaft and do a little massaging and we should be good to go. Thanks for looking into it for me.
Old 09-27-2013, 01:49 PM   #14
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I'd be careful with doing any cutting/grinding on the shaft. Might be better to put a small dimple in your headers near it. If you grind on your steering shaft you'll create a stress concentration point (AKA weak point) that could break at a lower stress than it was designed to handle.
Putting a dimple in your headers might not be what you want to do but the exhaust gasses can flow around the dimple/dent. If your steering shaft breaks then you are done driving.
Just my $0.02.
Nick S is offline   Reply With Quote
