JDP Motorsports
Old 09-21-2013, 02:20 PM   #1
L99CAMA2011
L99CAMA2011's Avatar
Whiteline adjustable toe links
I am about to install these bad boys. Love the way they look and they have a booted spherical bearing on one end and the poly bush on the other. Anyone has these or heard of them. They look killer in person.
Old 09-21-2013, 03:33 PM   #2
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
They look like they would hold up, but don't they need to be adjusted with an alignment?
Old 09-24-2013, 12:38 AM   #3
SPCBA
Drives: pleather and Chiclets
Met the owner of whiteline a couple times. Seen his car, seen him race. They have been in the vette market for a while. So deff not a new company that wont stand behind their products.
SPCBA is offline   Reply With Quote
Old 09-24-2013, 10:44 AM   #4
Denis
Denis's Avatar
Drives: 2010 SS
Whiteline is supposed to be good stuff.
Old 09-24-2013, 05:18 PM   #5
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
One word of advice, make sure you get those jam nuts real tight, because if they start loosen up, the car will get very loose in the back...I know this from experience with another brand...
So Cal Camaro is offline   Reply With Quote
Old 09-26-2013, 11:48 PM   #6
L99CAMA2011
Nothing I tighten comes loose trust me, plus I always use Loctite. Hey also guys, the car actually handle better with these than it did with the BMR spherical toe arms. Corners sharper and wraps around corners better.
Old 09-27-2013, 12:24 AM   #7
SPCBA
Congrats
Old 10-18-2013, 12:05 AM   #8
L99CAMA2011
Ok bad news guys not even a month and these Whiteline pieces are toast. Looks like the ball bearing end doesn't articulate like the BMR pieces and look what happened. Thank God I was driving at legal limits. I was actually doing like 20 mph when it let to.
Old 10-18-2013, 12:27 AM   #9
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
do you have any pics?
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 10-18-2013, 10:57 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The toe rod is a very simple design and you honestly don't get a better mounting design than a spherical rod end since they articulate very well and can handle the abuse of high horsepower and racing. Our BMR spherical rod end toe rods should perform much better than the Whiteline ones you have because the Whiteline toe rods uses a spherical rod end (different design than ours) on one end and a poly-urethane bushing on the other end. The poly-urethane bushing will only articulate so much before it binds and they are not well suited for higher horsepower cars or a bunch of racing.
If you can post up some pictures of the broken toe rod, I would really like to see what happened. I am surprised the spherical rod end gave out since the poly-urethane bushings should really be the weak point of that toe rod.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 10-18-2013, 11:18 AM   #11
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
When do the pictures start?
Old 10-19-2013, 12:15 PM   #12
L99CAMA2011
When you stop taking all the Popcorn. I see someone doesn't like to share. LOL. As you can see the end with the booted bearing rotates on 1 axis and is not like the BMR spherical QA 1 end. At first I thought they were just too stiff and would have loosen up after a few miles but I was wrong. Had I realized this I wouldn't have installed them. Honestly I expected this to happen.
Old 10-19-2013, 12:18 PM   #13
JusticePete
VIR Specialist
When you stop taking all the Popcorn. I see someone doesn't like to share. LOL. I tried post the pics but my Galaxy 3 isn't communicating properly with my PC.
I had to make more popcorn for you.
Old 10-19-2013, 12:26 PM   #14
L99CAMA2011
Great Buttered Popcorn, my favorite , thanks bro.
