Old 09-23-2013, 04:42 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
how tough is the oe lsd
my cars a week end driver no racing future mods will put me in the 450rwhp range. I dont go doing burnouts all the time but it might break them loose now and then. Im putting GM 3.91 gears in and am thinking of a Eaton Truetrac. Do I really have to upgrade the locker. I dont race. I just dont want to spend all this money to have the gears installed just to blow up the LSD. Was thinking about billet caps too. is the stock rear end really that bad. no 1 wheel peel. I know about the posi mod but would do the eaton over it.
real ZL1 wheels 285/305 Michelin Pilot Super Sports, Pray ported IM/TB, EFI Tuning Flex fuel kit, American Racing Headers long system w/ cats H pipe to NPP. 1LE suspension package.
JCunningham is offline   Reply With Quote
Old 09-23-2013, 06:20 AM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I pretty much use my car like you, have the 3.91 gears and am in the 460 rwhp range. I just did a straight gear swap - didn't upgrade any rear diff parts. I've had about 3K miles of trouble free use including a few hard launches and a couple of 1/4 mile runs - all good so far.
Certainly upgrading wouldn't be the wrong thing for you but I deemed it not needed for my use.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 09-23-2013, 07:00 AM   #3
2012REDSS
Drives: 2012 Camaro SS
I have the 3.91s, JRE posi mod, LPW diff cover, and I race mine every other weekend when I'm not deployed. I also drive it like I stole it. Dyno'd 607rwhp and 525ftlbs on 22's. If you dont race I think the eaton is over kill.
2012REDSS is offline   Reply With Quote
Old 09-23-2013, 07:25 AM   #4
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
Agree with all of the above! For your use I think it's overkill! I have 3.91's and only did the gears. I've done autocross, an HPDE road course event, and about 10 drag runs with no problems! I'm at around 420rwhp so in your case another 30 won't make much of a difference IMO!
Not a Camaro but it works for now!
Old 09-23-2013, 10:58 PM   #5
JCunningham
Drives: 2017 2SS M6
ok thanks
Old 09-24-2013, 09:19 AM   #6
JCunningham
Drives: 2017 2SS M6
I think this belongs in the drivetrain section.
Old 09-28-2013, 11:15 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
If anything, I would do at least the JRE posi mod. Think of it as cheap insurance for your rear end. It's roughly $200 and in order to do your gear swap, you would have to pull the LSD anyway.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-28-2013, 11:46 PM   #8
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
^This
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
