JUICEDMOTORSPORTS
Old 09-24-2013, 08:46 PM   #1
Blu Ray
NO BOOST
Blu Ray's Avatar
Drives: 2015 Black 1SS/RS/1LE*NPP*RECAROS
Send a message via AIM to Blu Ray Send a message via Yahoo to Blu Ray
IPS LFX TWIN TURBO 570 HP...$6300.00
Need advise, has anyone ever heard of IPS?? Whats there reputation opinions?
IPS 2012 Camaro V6 (LFX) Twin-turbo Kit: The BEST components. The BEST results. Period.
Our highly anticipated turbo kit for the 2012+ V6 Camaro is here! There is no other kit available for your Camaro that makes the numbers ours does on a stock LFX and pump gas — 460 rwhp and 443 ft/lbs of torque !! That is 575 HP at the engine, almost DOUBLE the factory output from a truly bolt-on turbo kit.
The incredible power gains come from using nothing but the best components in our kit. We have tested many many different turbos and turbo combinations over the last few years with different GM Corvettes and Camaros and have applied what has worked best to the new LFX Camaro. No expense was spared in R&D and we are proud to not just build the entire kit inside our 4 walls, but that we have managed to source 99% of the kit’s components from USA-made sources. MADE IN THE USA!!!
This kit is our "Entry Level" turbo kit. This is still uses quality components like Garrett turbos, TiaL wastegates and BOV, Fragola lines. It uses T3/T4 60 trim turbos. Older technology, but still Garrett quality!
A break-down of the BASE twin-turbo kit components are as follows:
2x Garrett GT28 Journal Bearing Turbos
2 x IPS TIG-welded 304 Stainless-steel Mid Pipes
2 x IPS 2.5” TIG-welded 304 Stainless-steel Downpipes
2 x ATP Internal Wastegates
1 x TiaL “Q” Blow-off Valve (Info here)
1 Χ 3” Aluminum Bar & Plate FMIC Core
1 x IPS Aluminum Intercooler Deflector Shield
1 x Oil Return Pump & Bracket
IPS Oil Feed & Return Line Kit featuring Fragola “Soft” Nylon Braided Hose & Black Fittings
IPS Sport Crimp Lines & Fittings. These are Mandated in Top-Fuel Racing for the absolute best in quality. No cheap China-bay Fittings Here!
IPS 3” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
IPS 3” 6061 Aluminum Charge-pipe
K&N Filters
IPS Lower Skid-plate
Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
RX Dual Check Valve Catch Can Setup
We want to make driving and racing a turbo-charged Camaro available to everyone, and the new kit we put together follows the same philosophy that has put IPS at the forefront of high performance motorsports for so many years.
FOUNDER - NY/NJ/PA Domestic Car Club Est.2013
Custom Grind Comp Cam 110 Lobe * Brian Tooley Push Rods, Springs * Kooks 1 7/8 LT Headers * Comp Cam Trunion Bearings * NGK TR55 Spark Plugs * Rotofab CAI * Dyno Tune * CNC Ported Heads * LS7 Lifters & Tray * GM Performance Dual Mode Exhaust * GForce 1000 HP Axels* BMR 1" Lowering Springs, Trailing Arms, Toe Rods, Upper Control Arms* Full Rear Bushing Kit * 504/462
Blu Ray is offline   Reply With Quote
Old 10-09-2013, 05:09 PM   #2
Juan8463
Drives: 2013 Black V6 Auto. Chevy Camaro Ls
Would this kit be recommended for a daily driver?? And would it have any effect on the mpg?
Juan8463 is offline   Reply With Quote
Old 10-09-2013, 05:25 PM   #3
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
If money wasn't a problem I would try to buy this. I'm interested in seeing who the first person is to do it, and see their response on it.
Idk where I read this but someone was questioning this kit not requiring to upgrade the fuel pump.
45thCamaro is offline   Reply With Quote
Old 10-09-2013, 05:48 PM   #4
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
HP Turbine has this kit (he was the prototype). PM him or post on the link below.
http://www.camaro5.com/forums/showthread.php?t=308593
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-09-2013, 07:40 PM   #5
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
IPS has build some of the baddest V6 Camaro's on the streets since 2011. All their work is documented here on the forums. Hands down the best turbo kits made for the V6.
Can't_C_Me is offline   Reply With Quote
Old 10-09-2013, 07:54 PM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Who makes the intercooler? I see mention of the intercooler piping, but not the radiator itself.
The T3/T4 is indeed a tried and true unit. You can buy rebuild kits for those things all over the place. That's the unit I would upgrade my '87 Dodge Raider with if I ever felt the need.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-09-2013, 08:28 PM   #7
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
hi, that would be my car. I use it as a daily driver and love it. I'm constantly playing around in it and i'll get 20 mpg. but just light driving I can do 25 mpg or better.
johnny I believe they made the intercooler from a core. I haven't found any name brand markings on it yet.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 10-09-2013, 09:18 PM   #8
JohnnyBfromPeoria
On my 285 mile drive to Las Vegas the day before yesterday I got 30.5 average MPG, per the DIC. And that's not a straight and level drive, either. Gotta love forced induction that's on when you want it and laying in wait when you don't, huh?
John B.
Old 10-09-2013, 11:05 PM   #9
45thCamaro
45thCamaro's Avatar
Any video of this thing running?
Old 10-09-2013, 11:46 PM   #10
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Take a look at his build thread a few videos in there. I believe one video in page 7 and a few in page 8
Old 10-10-2013, 12:39 AM   #11
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
How much is this setup? What does it push in HP?
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 10-10-2013, 01:08 AM   #12
JohnnyBfromPeoria
May I refer you to the title of this thread to answer your questions?
John B.
Old 10-10-2013, 07:46 AM   #13
HP Turbine
Boosted
HP Turbine's Avatar
The 25 mpg is combined city/highway. I used to average 26 mpg city/ highway. I'm sure if I sat on the highway for a while I could do 30
Old 10-10-2013, 07:53 AM   #14
tabshire95
Texas Raised
tabshire95's Avatar
Drives: 2012 RS Grey 2LT Camaro
This is actually a really good pricing for a twin if i'm not mistaken. I would love for someone to jump on this and get it, shame I don't have near the funds for this. I feel like a twin turbo, or even a turbo, is just so far out of my bank accounts mind right now =(.
-Live for the Thrill-
tabshire95 is offline   Reply With Quote
