Cold Air Inductions
Old 06-23-2014, 05:40 PM   #43
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Originally Posted by GretchenGotGrowl View Post
It will quite it down quite a bit. One question. Why are you running a x-pipe and a h-pipe.
Think he said he deleted his H-Pipe and resonators.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 06-23-2014, 05:41 PM   #44
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Ahh, I misread that. My apologies for the senior moment.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-23-2014, 05:44 PM   #45
MagnumForceGB
Drink some beer, helps focus.
Would he need to remove any exhaust components to help flow to spool the turbo's up?
Old 06-23-2014, 05:53 PM   #46
GretchenGotGrowl
I will pop a top as soon as I get home from work!
I would dump the hi-flow cats for the same reason you gutted yours. I would go with 2.5 inch pipe behind the turbo for at least 12 inches (I don't remember if the IPS kit comes with that section or not). Other that I think he's good. I have no cats and run the stock h-pipe with resonators back to MRT 2 mufflers. I have not seen any sign of back pressure issues.
Old 06-24-2014, 01:46 PM   #47
Sparkyz13Bee
Sparkyz13Bee's Avatar
Drives: 2013 Camaro 1LT
Originally Posted by walter78 View Post
I am looking to upgrade my car. It is my daily driver (25 miles a day, short trips). I want to get more power, and getter MPG over stock.
I like the idea of a twin turbo, but not sure if it's worth the money.
Anyone have twins installed on a 2013 LT RS with pictures of the install?
If you are ok with the expense twin turbos is the way to go. Very few ways you are going to be able to get close to 500hp to the ground and you can goto the website and see the install of a 2012. The silver Camaro is on the forum.
Sent from my Sparkyz iPhone using Tapatalk
Sparkyz13Bee is offline   Reply With Quote
Old 07-05-2014, 01:27 PM   #48
withoutt
Drives: 2014 Camaro LS
Hey!
So I ordered this Kit, IPS Twin-Turbo. I'm good friends with our main tuning shop up here in Wisconsin, And he said that this system is badass and raw in power. I am a daily Driver, and will be using this on a daily driver car. You want to keep your gear ratios stock if manual, the lower gears, the more torque/acceleration you will get. Your engine will be fine, as long as your not beating the hell out of it. If you decide you want to, upgrade your pistons, fuel pump. You will need a high performance clutch, or you will burn yours out faster than candy. However, stock v6 camaro w/ vmax throttle bottle and twin turbo, you will be faster than a stock SS, any v8, as well as just as quick as a ZL1, while getting 30 MPG highway, 22 city!
withoutt is offline   Reply With Quote
Old 07-05-2014, 05:32 PM   #49
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Originally Posted by withoutt View Post
Hey!
You on the money! My twin kit has been on my car since March 2012 and car is still rolling. And on stock internals and transmission. Only problems I've had was with the kit as it is custom, but all good now. But using any FI system isn't bullet proof.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Can't_C_Me is offline   Reply With Quote
Old 07-05-2014, 07:56 PM   #50
Sparkyz13Bee
If I were to upgrade to a ZL1 fuel pump. Can I get 500hp to the ground?
Old 07-05-2014, 09:08 PM   #51
GretchenGotGrowl
Do you have a manual or automatic? With a manual it should be no problem. With an auto you cab do it, but you are at the ragged edge of the hpfp. With a good tune you should be good, but I.wouls dial it back myself.
Old 07-05-2014, 09:09 PM   #52
Sparkyz13Bee
I have a manual. I wanna in the neighborhood of 500. Or at least be able to tune it up to that. And then turn it back some for daily use.
Old 07-05-2014, 09:36 PM   #53
GretchenGotGrowl
You will be fine. Cant_c_me has been living in thay range with a medicore tune for a while.
Old 07-06-2014, 12:20 PM   #54
withoutt
I'm at 534 at wheels with stock fuel pump, manual. But I also have a 2014.
Old 07-06-2014, 01:43 PM   #55
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Whoa. Pushing it a little? Or is the tune solid? Those are big numbers lol
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood
DSX_Camaro is online now   Reply With Quote
Old 07-06-2014, 07:06 PM   #56
GretchenGotGrowl
Very nice numbers. That's about 630 hp at the crank, which is where I ran out of hpfp. We could have gotten a little more with the meth, but I wanted that just for safety.
