Old 09-25-2013, 12:23 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Trailing ARM ?
Who makes the best trailing arms for drag racing? Thanks
Craig B is offline   Reply With Quote
Old 09-25-2013, 12:35 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You could debate that to the end of time but BMR and Pfadt both make a great set. Both are much stronger than stock. The Pfadt set weighs a little less but costs a little more. If you go with BMR make sure to pick up the outer trailing arm bushings as well. They are a separate item. If you have any questions feel free to hit me up.
Old 09-25-2013, 01:25 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Pfadt BMR and Spohn are all great choices. Personally, I think the Pfadt trailing arm and toe rod package is is a great value. Feel free to call, PM or email me with questions.
Best regards,
Tyler
888-308-6007
Old 09-25-2013, 01:47 PM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks for the replies. I do like the quality of the parts I have seen from Pfadt.
Old 09-25-2013, 02:11 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Is your 5th Gen a dedicated drag car or street driven weekend warrior?
Old 09-25-2013, 02:12 PM   #6
Apex Motorsports
The quality and engineering of the Pfadt rear arms are second to none.
Old 09-25-2013, 02:14 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I will say that our BMR trailing arms with spherical bearings (TCA027) and rod ends (TCA033) are going to be stronger than any trailing arm with poly-urethane bushings. With any trailing arm that utilizes poly-urethane bushings the bushings will be the weak point of the arm itself. If you are looking for the strongest trailing arm possible I would put our BMR trailing arm with the spherical bearings against anything out there.
BMR trailing arm with the spherical bearings (TCA027)
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 09-25-2013, 03:06 PM   #8
Craig B
Craig B's Avatar
Drives: 2013 1LE
They do look beefy, are they made of Cromemoly?
Old 09-25-2013, 03:59 PM   #9
Craig B
Craig B's Avatar
Drives: 2013 1LE
I missed this. Just a weekend warrior, I have had it since May and only have 1400 miles on it.
Old 09-25-2013, 04:06 PM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
They are actually made of a boxed mild steel. If you are looking for something a little lighter and plenty strong enough to handle anything you are going to throw at it I would look at our BMR trailing arms with the rod ends (TCA033) which are made out of DOM mild steel.
T.C. Davis
813-986-9302
Old 09-25-2013, 04:18 PM   #11
JusticePete
Do your plans include significant RWHP increases or is your goal the best possible launch with OEM power?
Old 09-25-2013, 05:41 PM   #12
Craig B
Craig B's Avatar
Drives: 2013 1LE
I made 490 RWHP with a cam, heads, LT, and usual bolt on goodies. I just added a ECS kit and meth. I am looking @ 700 or so. I should know by the weekend how much power it makes.
Old 09-26-2013, 09:35 AM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
With that a mount of power a good set of trailing arms (and more) will definitely be needed to help you get the power to the ground.
It is crazy the amount power these cars make on a regular basis, I remember back about 10 years ago when 500hp was a lot of power.
T.C. Davis
813-986-9302
Old 09-26-2013, 09:51 PM   #14
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Is anyone making LCAs for the newer style suspensions
