JUICEDMOTORSPORTS
Old 09-26-2013, 12:02 AM   #1
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
Vibration issue
I'm having the worst luck with this car and highway driving vibration. Imagine having your tires unbalanced all the way around and now imagine driving 75 on the highway. That's what my car feels like when I go that speed. I've had the tires balanced and I've had the car aligned 3 different times. Neither of which has helped with the shake. What else could lead to this issue?
I don't want to take it to the dealer just to have them turn me away or for them to charge me an arm and a leg to do something I could have done on my own.
Dfault is offline   Reply With Quote
Old 09-26-2013, 09:39 AM   #2
ichriscamaro
BlueDiamond
Drives: 2015 2SS 1LE RRM
Did you try the Road force balancing. If its just a problem with balancing , that should fix it. Also does it always happen or only during first minutes driving. I had a similar issue but I think the tires do this when you first drive them until they warm up.
Good luck !
ichriscamaro is offline   Reply With Quote
Old 09-26-2013, 09:42 AM   #3
Dfault
Dfault's Avatar
It happens any time of the day while I go 75 on the highway. Is the road force balancing the one that tells you if the tire is good or bad as well? I might need to do that, because I know that when I took delivery of the car the rear tires were the only new ones and the front ones were the ones that came on the car when the dealer received it.
Old 09-26-2013, 10:50 AM   #4
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
Is your car lowered? I had the same problem too a few things I would check. Replace your driveshaft bolts they could become loose. They are not supposed to bet retihjtened and re used. Then also the car being too low. I raisedmy car and no vibration.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 09-26-2013, 11:32 AM   #5
Dfault
Dfault's Avatar
I guess vibration would be the wrong way to describe it since there is definitely steering wheel shake involved.
No my car isn't lowered, but knowing my wheels are balanced and my car is aligned is leaving me scratching my head...
Old 09-26-2013, 11:42 AM   #6
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
Op - Check you front hubs. If they are bad sometimes will cause a vibration in the steering wheel.
Does the wheel vibrate when braking?
How many miles are on the car?
What do the front tires look like? If you have a pic please post it.
Ricardo@Phastek is offline   Reply With Quote
Old 09-26-2013, 12:24 PM   #7
Dfault
Dfault's Avatar
I can take pictures of the tires just give me a little white, and yes even at speed the steering wheel will shake when I brake. However, nothing shakes when I'm going below 65-70.
Old 09-26-2013, 01:23 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Are you on OEM wheels and tires?
Old 09-26-2013, 01:43 PM   #9
Dfault
Dfault's Avatar
Yes sir
Old 09-26-2013, 01:55 PM   #10
JusticePete
Yes sir
Rear tires are new?
When you look closely at your front tires do you see any signs of cupping or feathering?
Is there any pulsing in the brake pedal when you apply the brakes?
Old 09-26-2013, 02:02 PM   #11
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
Bald spot on tires maybe? Have you ever locked them up?
45thAnniversary2SS is offline   Reply With Quote
Old 09-26-2013, 02:41 PM   #12
Dfault
Dfault's Avatar
Old 09-26-2013, 02:42 PM   #13
JusticePete
Brakes feel normal?
Old 09-26-2013, 02:42 PM   #14
Dfault
Dfault's Avatar
Dark spot is just from the grass being a little wet when I parked the car.
