Old 09-27-2013, 08:55 AM   #15
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by RMK1201 View Post
Stock wheels and tires
With the 10 SS staggered wheels and tire the ZL1 bars will work for you. You'll have to upgrade the RLCAs and use the Z front enlinks and droplinks. Drill out the 10mm holes in the front strut tabs for the 12mm Z link studs. Get some hardened washers for the nuts that hold the sway bar straps in place.
Old 09-27-2013, 11:42 AM   #16
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Would I HAVE to upgrade my end links or are the stock ones going to be fine, keep I mind the car is only used for daily driving and no track usage what so ever.
You wouldn't have to upgrade your end links unless you wanted to. The factory end links generally hold up quite well if you are mainly going to be using the vehicle for daily driving duty. If you plan on road racing or auto crossing the car it definitely wouldn't hurt to upgrade the end links to something that will handle the abuse better like our BMR end links (ELK004)
Old 09-27-2013, 11:47 AM   #17
JusticePete
VIR Specialist
A 2010 strut has a 10mm hole for the endlink. A ZL1 sway bar has a 12mm hole for the 12mm endlink stud.
Old 09-27-2013, 12:34 PM   #18
SSICKO
SSICKO's Avatar
Drives: SSICKO
Alright thanks
Slowhawk Performance Built & Tuned
SSICKO is offline   Reply With Quote
Old 09-27-2013, 06:44 PM   #19
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Originally Posted by Retro69 View Post
I went with Pfadt springs and ZL-spec sway bars. Huge improvement.
Got 'em from Tyler at JDP!
Sent from my iPad using Tapatalk HD
Retro69 is offline   Reply With Quote
Old 09-28-2013, 01:46 AM   #20
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Go Hotchkis, you wont regret it.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 09-28-2013, 09:58 PM   #21
SSICKO
SSICKO's Avatar
Drives: SSICKO
Ahhhhh im still undecided!
Old 09-28-2013, 10:18 PM   #22
JusticePete
VIR Specialist
What would make you smile every time you drove your car?
Old 09-29-2013, 03:50 AM   #23
SPCBA
Drives: pleather and Chiclets
Your entire catalog installed on my car? Throw in your L28's wheels and I might even show some teef in my smile
SPCBA is offline   Reply With Quote
Old 09-29-2013, 11:33 AM   #24
JusticePete
VIR Specialist
Old 09-29-2013, 12:12 PM   #25
L99CAMA2011
L99CAMA2011's Avatar
He said TEEF , wow haven't heard that in a while.
Old 09-29-2013, 01:24 PM   #26
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
had the pfadt springs and sports sways, upgraded to the zl1 pedders bars from rob at wretched had to change the rear lca's but it was worth it
enyce0387 is offline   Reply With Quote
