HeadlightArmor
Old 09-26-2013, 09:28 PM   #1
Irishmic
Drives: 2014
Rear end question
Im too lazy to look it up....but is the rearend in the v6 camaros the same in the ss V8 ??? I know in the old days the 6cyl had a light duty 10 bolt vs the hd 12 bolt..Thanks
Irishmic is offline   Reply With Quote
Old 09-26-2013, 09:35 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
V6 manual trans is the same as ss
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is online now   Reply With Quote
