HeadlightArmor
Old 09-27-2013, 03:24 PM   #15
Edwin320
Drives: 2012 Camaro Convertible 2SS RS M6
Originally Posted by HDRDTD View Post
With the no-lift shifting , the engine maintains it's rpms when you push in the clutch, preventing it from just climbing right up and hitting the rev limiter no matter how long it takes you to complete the shift.
With the conventional method of power-shifting, if you shift fast enough, all is good. If you miss a gear, the engine will continue to rev right on up.
Ah. Thanks for clearing it up. :-)
Ed 2012 2SS RS M6 'Vert
Edwin320 is offline   Reply With Quote
Old 09-27-2013, 03:52 PM   #16
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Maybe this will make learning a manual easier for me. I have to learn before I get my ZL1.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 09-27-2013, 03:59 PM   #17
Eich
Drives: '11 SW/Beige 2SS RS Manual
At high RPM, my SS won't go into 2nd without grinding even with a lift-shift. I can't imagine what horrors await with a no-lift-shift.
Eich is offline   Reply With Quote
Old 09-27-2013, 04:01 PM   #18
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Originally Posted by Jenner View Post
Why does the back of the car have the 2014 ass and 2013 front end?
Chevy has claimed it was for aerodynamics.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 09-27-2013, 04:02 PM   #19
vcyclenut
Drives: 2011 ctsv
we have had clutchless full throttle shifts on motorcycles for years not sure why with all the electronics they couldn't do the same for a car.
we put a sensor in the shifter linkage the cuts the ignition for a split second and allows it to slip into the next gear. full throttle the entire time no clutch needed.
vcyclenut is offline   Reply With Quote
Old 09-27-2013, 04:02 PM   #20
ZL1RHINO
Drives: 2013 black on black
So are we able to do this in a 2013 zl1
ZL1RHINO is offline   Reply With Quote
Old 09-27-2013, 04:14 PM   #21
Mrose
Mrose's Avatar
Drives: 2012 ZL1 Victory Red !!!!!!!
All ZL1's have no lift shift ! So yes the 12, 13, and 14 are equipped to do it!
ZL1 Current Status:6000 #1251
1000 Initial Order 11/28/2011 -
1100 Order accepted at dealer: 11/28/2011 - QBDTB8
2000 Order accepted by GM: 04/23/2012
2500 Order preferenced. Pulled to the production system 4/24/2012
3000 Accepted By Production Control: 04/25/2012 - TPW 05/07/2011
3100 Sequenced: 05/03/2012
3300 Scheduled For Production:5/4/2012
3400 Broadcast: 5/5/2012
3800 Produced: 5/11/2012
4B00 Available To Ship car is bayed: 5/13/2012
4200 Shipped: 5/30/2012
5000 Delivered To The Dealer: 6/5/2012
6000 Delivered To Customer: 6/6/2012
Mrose is offline   Reply With Quote
Old 09-27-2013, 06:52 PM   #22
mel1
Yeah buddy
mel1's Avatar
Drives: 2010 Camaro SS Inferno Orange
Cool feature....but why not just buy the A6 oops shouldn't have said that
2010 SS IOM L99,Heritage grille,Rear Bowtie Delete
mel1 is offline   Reply With Quote
Old 09-27-2013, 07:20 PM   #23
KCCO
Drives: 2010 Cobalt SS Stage 1
Originally Posted by karnov View Post
Is this only in the ZL1, or is this in the SS as well. My previous car had this feature and my 1LE SS won't be ready for delivery until the end of next month. I have been wondering if this works on the SS?
**EDIT**
I saw the previous post so I assume this is something specific with the M6 transmission which would mean it will work in the SS model???
It will not. The SS is a LS3 N/A engine, therefore there's no reason to keep the boost(cause it doesn't build any) between shifts. The ZL1 is supercharged and therefore holds the boost between shifts instead of loosing it. My Cobalt SS T/C is the same.
KCCO is offline   Reply With Quote
Old 09-27-2013, 08:09 PM   #24
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
dang I don't know if I could do that. Would be very nerve wrecking the first time around
Proud owner of litho #179 Click Picture for Build Thread
Old 09-27-2013, 08:13 PM   #25
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
and cooling. with the diff,oil, trans, and intercoolers being up front the '14 and up front isnt the best. They did function before form in 2014...
I used the piss outta that feature(no lift shift) on my Turbo cobalt. I embarassed countless Mustang GTs (pre 5.0) and shocked some GTslows(GTOs)
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 09-27-2013, 08:39 PM   #26
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Bleed the hydraulic clutch, if you still have the same problem you need a new clutch. I'm on my 3rd clutch....when you cant smoothly no lift it is time to replace the clutch.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 09-27-2013, 08:48 PM   #27
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
DJ-Silver 2SS's Avatar
Drives: 13 IOM ZL1 M6 & 10 SIM 2SS M6
Send a message via Yahoo to DJ-Silver 2SS
I've used this feature a lot, it is fun and easy. My friends and wife say, per all my videos, that I am heading to the grocery store, or that's what it looks like because it doesn't take that much effort.....
2013 IOM ZL1 #002415 Born 09/13/12
2010 SIM 2SS/RS #005549 Born 05/02/09
DJ-Silver 2SS is offline   Reply With Quote
Old 09-27-2013, 09:14 PM   #28
jcamo
jcamo's Avatar
Drives: 2ss/rs/2013 camaro 1LE
So this can be done on a 2013 1LE???
jcamo is offline   Reply With Quote
