HeadlightArmor
Old 09-27-2013, 08:53 PM   #29
DavidW
Drives: 2013 ZL1 Vert Auto IOM
Originally Posted by vcyclenut View Post
we have had clutchless full throttle shifts on motorcycles for years not sure why with all the electronics they couldn't do the same for a car.
we put a sensor in the shifter linkage the cuts the ignition for a split second and allows it to slip into the next gear. full throttle the entire time no clutch needed.
I think it may be related to the design of the transmission in motorcycles vs automobiles , sequential in motorcycles vs cars with the H type shift pattern, I have shifted gears in standard cars with no clutch but I had to rev match going into the next gear, and I have done no clutch up and down shifts on dirt bikes with no grinding or other noises, although the shifter effort was higher
Originally Posted by Eich View Post
At high RPM, my SS won't go into 2nd without grinding even with a lift-shift. I can't imagine what horrors await with a no-lift-shift.
on my cobalt SS when I no lift shifted into second it would usually grind sometimes it would just grind and not go into gear at all , I figure the synchronizer for second was weak , thats one of the reasons I started getting automatics ,there's less to worry about transmission wise , both self induced and defects
DavidW is offline   Reply With Quote
Old 09-27-2013, 09:52 PM   #30
doc7000
Drives: 2004 Pontiac Grand Prix
I remember when GM produced the turbo charged Cobalt SS, they also used a no lift shift algorithm. Pretty much when you hit the clutch pedal the computer drops the rev limit dropping rpms to around where it needs to be for the shift.
doc7000 is offline   Reply With Quote
Old 09-27-2013, 10:02 PM   #31
spideronjuice
Drives: 2014 Camaro ZL1 Ashen Gray Metallic
Originally Posted by Jenner View Post
Why does the back of the car have the 2014 ass and 2013 front end?
The reason Chevrolet didn't change the front fascia on the 2014 ZL1 is because the front of the car is fully functional and creates a 140LBS of down force, so changing the design would also change the performance.
spideronjuice is offline   Reply With Quote
Old 09-27-2013, 10:24 PM   #32
doc7000
I saw a black 2014 1LE Camaro which looked insane, best looking 5th generation Camaro I have seen so far.
Old 09-27-2013, 11:25 PM   #33
VegasZL1
Drives: 2015 Z/28
Originally Posted by HDRDTD View Post
With the no-lift shifting , the engine maintains it's rpms when you push in the clutch, preventing it from just climbing right up and hitting the rev limiter no matter how long it takes you to complete the shift.
With the conventional method of power-shifting, if you shift fast enough, all is good. If you miss a gear, the engine will continue to rev right on up.
What do you mean by, "maintains its rpms..."? This is not my experience.
VegasZL1 is offline   Reply With Quote
Old 09-28-2013, 12:05 AM   #34
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
Originally Posted by menendez1293 View Post
dang I don't know if I could do that. Would be very nerve wrecking the first time around
I thought the same thing until I gave it a go...now it's a daily habit.
My Toys:
2012 ZL1 Coupe (M6) #80
2012 Nissan Titan
2007 Ducati 1098
2006 Yamaha R6 (Track/Race Only )
IcePick06 is offline   Reply With Quote
Old 09-28-2013, 07:35 AM   #35
DrkPhx
DrkPhx's Avatar
If you do it quick enough and at redline it won't flare; other it will flare up in rpms.
Old 09-28-2013, 07:46 AM   #36
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
You gotta give it a try! These cars are designed for wicked launches and the No-Lift-Shifting just adds to the adrenalin rush. First time I tried it, I Failed! I just automatically let off the throttle as I hit the clutch pedal. Took a few deep breaths, slowed down, I was on an open stretch of hiway, in second gear and stomped on it and held down until I was in fourth! Then of course I had to try it from a dead stop starting with Launch Control thru Fourth! Did it a few times and easily used a quarter tank of fuel. I probably averaged TWO Miles Per Gallon! Definitely was worth it!
Sent from my iPad using Tapatalk - now Free
Normagene is offline   Reply With Quote
Old 09-28-2013, 08:27 AM   #37
OPP
OPP's Avatar
Drives: 2018 MBM ZL1 Auto
I do this all the time every day. Just floor the gas and don't lift my foot off it. I don't even have to press the clutch. Yes, having an automatic does help with no lift shift.
OPP is offline   Reply With Quote
Old 09-28-2013, 08:39 AM   #38
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Originally Posted by jcamo View Post
So this can be done on a 2013 1LE???
YES, but you wont gain anything by it. The no lift shift is designed on boosted applications to keep boost in between shifts. 1LEs are N/A so if you want to, go for it, you just might be buying clutches more.
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 09-28-2013, 09:48 AM   #39
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Funny that this wasn't on the 2013 M6 cars.. Hell my 2003 SRT4 had it.
franknbeans is offline   Reply With Quote
Old 09-28-2013, 12:17 PM   #40
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
this is a fun lil feature in my 2010 Cobalt SS.. holds the boost pressure so no LAG love it..
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 09-28-2013, 02:12 PM   #41
traildevil
traildevil's Avatar
Drives: 2013 Chevrolet Camaro LS
I'm gonna go try this in my 2013 LS 6spd right now, be back in a little bit and let you guys know how it works out!
...JUST KIDDING!!!!!!
traildevil is offline   Reply With Quote
Old 09-28-2013, 03:59 PM   #42
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
That's because your trans is a POS. I had 2nd gear and few other things replaced under warranty for something similar. It's shifts smooth now.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
