JUICEDMOTORSPORTS
Old 09-27-2013, 01:43 PM   #1
intensifi
Drives: '12 2LT Convertible
Which v6 suspension upgrades are bolt-ons and which require major effort
I've heard some of the upgrades require pulling the entire rear end out first.
Which ones are "easy" and could be done with a floor jack and/or lift (by me) without major surgery?
Note: I am not looking to lower the car. Given my driveway, I can't.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 09-27-2013, 01:49 PM   #2
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
Swaybars! you'll feel the difference right away no more understeer and your rear will feel more planted during heavy acceleration
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 09-27-2013, 01:58 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Originally Posted by intensifi View Post
I've heard some of the upgrades requires pulling the entire rear end out first.
Which ones are "easy" and could be done with a floor jack and/or lift (y me) without major surgery?
It really depends on what kind of driving you are planning on doing with the car and your expectations. Do you want to concentrate more on straight line performance or handling with your Camaro? Let me know and I would be more than happy to throw out some recommendations to you.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 09-27-2013, 02:05 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
All things handling and suspension with the 5th Gen Camaro starts with the foundational bushngs. Your 12 vert will benefit greatly from a set of EP1200 sub-frame inserts and EP6579 radius bush inserts. The inserts provide stability to the IRS and reduce rear end step out a.k.a. rear end steer a.k.a. loose rear end. Up front the radius bush inserts reduce the dynamic range of caster change improving the on center steering feel. They are inserts making installation easy and straight forward.
Follow up the insert installation with a Pedders tight spec aggressive street alignment. You'll be amazed at the difference in your Vert. If you never add another mod, you'll love driving your Vert. If you choose to further mod your suspension your foundation is in place.
Here is the index to The Book of 5th Gen.
Pedders 2010 Chevrolet Camaro Suspension Evaluation
Foundational 5th Gen Required Upgrades
Lowering Coils and Coilovers
Trouble Free, OEM Quiet V6 Lowering
Sway Bars
Suspension Bushes
ZL1 / CTS-V Brake Upgrade for the SS
Wheels and Tires
Bush Timing, Alignment and Torque Specs
Pedders USA Camaro 2.0
Lingenfelter L/28 Tech
5th Gen Wheel Hop and Drag Race Setup
Thermal Management
Running Changes Made to the 5th Gen by Chevrolet
Public Track Test #1
Public Track Test #2 Camaro vs. Mustang Supercar Shootout
2013 Strut Mounts, Pedders Coilover Pre-Compression and Ride Height Settings
Old 09-27-2013, 05:04 PM   #5
intensifi
thanks for the info!
I'm looking for both straight line performance and better handling in the turns.
Old 09-27-2013, 05:30 PM   #6
JusticePete
Exactly why you start with the foundational bushes.
