Old 07-12-2009, 04:16 PM   #1
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Did some datalogging...
Ok... took the car back (V6 automatic) to the track today (new PB 14.629 vs last weeks 14.698... LOL! Doing that DA correct stuff the car is running 14.33 two days in a row at two different tracks... just noticed... cut my best 60' too! 2.118)
So I did some data logging... Here is the graph of one of my runs. You can see I stalled the car up to almost 2300... then you can see I had TC on and when I spun the car pulled a bunch of timing...
Timing looks a little bit lower than I had previously observed... I don't have the logs.. but when I was goofing around a few weeks ago I seem to remember the timing basically locking in at 24 or 25 degrees...
The inlet air temps actually go DOWN as I make the run! Ambient temp was 72 degrees... the car was kind of hot lapped....
Best run of the day was the first one! I drove an hour to get to the track... parked the car for 20 minutes and made a run... Second run I waited 30 minutes and my time crept up to 14.778... wait again... again a hair slower... yes the ambient temp was going up but only a degree or so... Just seemed kind of odd.. Guess I need to wait longer between runs... but the first run doesn't need as long...
There is also some odd stuff at the 3rd gear shift... not sure what's going on there... the dashhawk technically doesn't support the 2010 Camaro... so not sure what that is... on the other runs it gets a few bad samples in 3rd gear also...
Ok... enough rambling... here's the log... Click on it to see the full size for better view..
scrming is offline   Reply With Quote
Old 07-12-2009, 04:52 PM   #2
scrming
scrming's Avatar
And here is with TC off and a bit of tire spin! LOL!
Old 07-12-2009, 05:48 PM   #3
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2016 Silverado
So we're talking V6 with Auto trans here...
Old 07-12-2009, 06:01 PM   #4
scrming
scrming's Avatar
yes, v6 auto... I fixed my 1st post..
