Emblempros
Old 10-17-2013, 09:58 PM   #15
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Originally Posted by BaylorCamaro View Post
Would it be possible to swap the wheels left to right and right to left and see of the pull changes sides? Or would the side specific tires for the ZL1 make that test pointless?
Even though they are directional I would still try that. We could also swap out with my car but damn we live pretty far away from each other.
Old 10-17-2013, 10:02 PM   #16
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Yuuuuup. I was going to say I could swap with Alex but he's going to be gone Saturday. I may try swapping them tomorrow.
May also see if discount can Road Force balance.
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 10-18-2013, 09:00 AM   #17
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I went to discount this morning, unfortunately they can not road force balance. Just for the heck of it, I had them check the normal balance, and as I suspected everything was fine.
I will try swapping the front wheels/tires tonight to see if that changes the pull at all.
Old 10-18-2013, 10:29 AM   #18
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
I have never run direction tires backwards. This will be interesting. One other thought. ANY front Camaro will work for this is there is an SS or 1LE owner close by.
Old 10-18-2013, 10:50 AM   #19
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
You could take it back and have the tech recheck the allignment and see if it is the same as the adjustments. If so you could return it to the stock settings and try that. if it still pulls it could be an issue with the electric steering since the force feels different from left to right. Let the tech drive it that did the allignment. That is the most bothering problem when you have to take it back and forth to the mechanic to try and resolve an issue. I've been there done that with my 2010 SS.
KLR ZL1 is offline   Reply With Quote
Old 10-18-2013, 11:17 AM   #20
mlee
www.CamaroFest7.com
mlee's Avatar
Ahhh yes what Pete says. SS wheels work too and someone may have as set in the garage.
Eric also has a great point about electric steering. One reason I mentioned PTM5.
Old 10-18-2013, 11:37 AM   #21
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Front cast has .4* difference, could that be anything?
Old 10-18-2013, 11:40 AM   #22
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I'll have to check around.
The tech that did this is Jaime, so I have every bit of confidence that his work is spot on, that's the reason I drove 50 minutes to get an alignment, lol. However he said he would look into the calibration of the machine.
Old 10-18-2013, 11:41 AM   #23
JusticePete
Setting caster, which is NOT adjustable from the factory on a 5th Gen Camaro, 0.50 different side to side helps with driving on crowned roads. It is a standard practice.
Old 10-18-2013, 11:45 AM   #24
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
That's what I thought, but wanted to double check that nothing got thrown off when it was curbed.
Old 10-18-2013, 12:03 PM   #25
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Looks like according to tirerack you can cross rotate directional tires for trouble shooting purposes.
http://www.tirerack.com/tires/tirete....jsp?techid=12
Old 10-18-2013, 12:23 PM   #26
mlee
www.CamaroFest7.com
mlee's Avatar
Yeah, I've done it before. Swapping front tires is one of the 1st things to do when troubleshooting a pull.
Old 10-18-2013, 12:25 PM   #27
JusticePete
Great find. I learn something new every day.
Old 10-18-2013, 01:51 PM   #28
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I got a hold of someone from the club, I will be going later tonight and putting his wheels on. I really hope this is the issue..
