Old 10-01-2013, 06:48 PM   #1
driser
driser's Avatar
Drives: 2010 Camaro SS
brake pad swap
Just finished up a track weekend at Road Atlanta with Hawk DTC 30 pads (front)... much improved braking. No significant decrease in braking from the start of the sessions to the end (30 minutes).
Now it is time to swap back to the Hawk street pad, so looking for any advice from those that are pros at this. Hoping to try it without removing the calipers, so if someone has been doing this, please give me some insight.
This was also the first time out with the Michelin Super Sports....what a great tire. Highly recommend for anyone who is looking for a street/track tire. Expensive, but worth every penny coming down the hill to turn 12!
Thanks
driser is offline   Reply With Quote
Old 10-02-2013, 12:35 AM   #2
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 chevy & 2011 1SS/RS manual
its really easy. just take your time. after the first time you can do it in a few minutes a wheel. who was the group that you ran with at rd atlanta? im hoping to go with nasa in december.
http://www.camaro5.com/forums/showth...=diy+brake+pad
JOHNSONROD is offline   Reply With Quote
Old 10-02-2013, 07:24 AM   #3
driser
driser's Avatar
Chin motorsports is the group I run with.
Old 10-02-2013, 12:57 PM   #4
Synner
Drives: not stock
pop the pins out
remove pad
push pistons back in slightly if necessary
Lube back of pad and insert pad
Lube pins and insert pins
clean rotor/pad with brake cleaner anywhere you, your fingers, or anything else touched braking surface
If you weren't drinking beer through each step you're doing it wrong.
Old 10-02-2013, 01:02 PM   #5
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
I had understood that it's not a good idea to swap pad types without turning the rotors, because the residual material from the previous pad is still on the disk and prevents proper braking with the new pad.
But I've also heard that you can do just what you're doing- swap in track pads at the track, then swap back.
Are there any brake gurus out there that could shed some light on which is true?
Thanks
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 10-02-2013, 01:07 PM   #6
Synner
Drives: not stock
Typically if you stick with the same manufacturer their compounds are compatible but it doesn't hurt to ask before purchasing. But yes pad residue from an old pad can cause overheating and poor performance leading to gunked up everything with embedded pad/rotor material.
Old 10-02-2013, 01:17 PM   #7
Synner
Drives: not stock
...and you may need to re-bed the pads to the rotors and go through the break in procedure again before the next track day to scrub the rotor and have it ready for action.
Old 10-02-2013, 03:15 PM   #8
SPCBA
Drives: pleather and Chiclets
Always good to brake cleaner and steal wool or sand paper off the old pad and do a proper bed in process on new pads.
SPCBA is offline   Reply With Quote
Old 10-02-2013, 03:52 PM   #9
driser
driser's Avatar
Originally Posted by Synner View Post
pop the pins out
remove pad
Thanks for all of the info...do you have a recomendation for the lube?
Old 10-02-2013, 05:24 PM   #10
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Outside of being a little noisy, I run my track pads all the time and I believe Jordan from JDP runs the same pad that you are and he runs his on both the street/track.
So Cal Camaro is offline   Reply With Quote
Old 10-02-2013, 06:35 PM   #11
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
YES, Permatex® CeramicExtreme Brake PartsLubricant..
http://www.permatex.com/products-2/p...bricant-detail
Higher temps and it works well for both the street and track.
You can find it on the shelf at Advanced Auto.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 10-03-2013, 08:17 AM   #12
driser
driser's Avatar
Thanks.
Yea I can put up with the noise, but it is the dust on the new Forgelines (polished) that I can't handle. They cleaned up easy (thanks to Adams), but even short drives end up with too much dust.
Old 10-03-2013, 01:19 PM   #13
Synner
Drives: not stock
T.
Yup thats the best stuff I've ever found as well as longest lasting. Although whoever came up with the purple color should be shot.
Old 10-03-2013, 09:18 PM   #14
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Thanks.
Yup, the dust is the other issue....I make sure my Forgeline's have a good layer of wax on them at all times....then just blow them off with air compressor.
