JUICEDMOTORSPORTS
Old 10-01-2013, 09:35 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
need help with front springs installation
I was installing my front BMR lowering springs and I thought everything was going smoothly until I got to the strut tower under the hood. After everything is tightened up it is still seperated by like a 1/4 in. Does anybody know what I did wrong?
camarosspower is offline   Reply With Quote
Old 10-01-2013, 09:43 PM   #2
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
It's normal.
http://www.camaro5.com/forums/showthread.php?t=320594
amanc96 is offline   Reply With Quote
Old 10-01-2013, 10:02 PM   #3
camarosspower
I hope it is. Its just so weird . So it is drivable right. Any way to fix it?
Old 10-02-2013, 10:08 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That space is supposed to be there because the rubber lined retaining washers pivot when the steering wheel is turned. Without that space there it would bind and you would run into issues. You are good to go and everything looks like it should.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 10-19-2013, 11:21 AM   #5
camarosspower
Well after three weeks of having the lowering springs its been real good. I've had a lot of compliments lately. But yesterday I noticed that something hits hard in the front when I go thru a small bump. Its like a big thud. Anybody have any idea what that could be? I have 61k miles on the car already
Old 10-20-2013, 11:34 AM   #6
camarosspower
I really don't think its my shocks because it doesn't sound like that on every bump. It actually sounds like something is loose. Is that possible . Do I need to re torque again??
Old 10-20-2013, 11:40 AM   #7
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Most likely endlinks.
Old 10-20-2013, 02:32 PM   #8
camarosspower
Its mostly on the front most of the time. On the rear too just not as frequently
Old 10-20-2013, 02:52 PM   #9
JusticePete
VIR Specialist
Tighten the endlinks. 99% of the time it is the endlinks.
Old 10-20-2013, 03:11 PM   #10
camarosspower
Ok will do Pete. I noticed that the sound is coming from the strut towers. I have the car on jack stands. I lifted a tire with the floor jack and then dropped it. That's when I hear it. Ever since I lowered the car, the tower caps became like a 1/4 in separated from the tower. Is that normal?
Old 10-20-2013, 05:12 PM   #11
JusticePete
VIR Specialist
Take a look at this video an see if yours looks and acts the same.
Old 10-20-2013, 07:05 PM   #12
camarosspower
O ok. So its not that? Is it suppose to hit?
Old 10-22-2013, 04:46 PM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Just go back check everything that was loosened up during the install and make sure it is all tight.
This could definitely be the case also. I would make sure the end links are tight and if they are see if there is any tolerance built up in the end links that shouldn't be.
The gap between the retaining washer and shock towers is normal because the retaining washer pivots back and forth when you turn the steering wheel. That gap was there when the car was had the factory springs also. If you don't get this figured out give me a call here at the shop and we can go over everything and get this figured out for you.
T.C. Davis
813-986-9302
Old 10-23-2013, 04:00 PM   #14
camarosspower
Thanks Kyle . I ll be working ot for the next couple of weeks. I'll get with you then. Thanks again.
