HeadlightArmor
Old 10-02-2013, 11:26 PM   #1
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
whipple vs maggy??
Anybody got some good comparison data on these two? Interested to see why some people say the maggy has better volumetric efficiency than the whipple. Whipple claims 99%..... Differences in pully upgrade costs in whipple vs maggy? Output gains vs each other???
Thx!
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 10-03-2013, 08:02 AM   #2
old motorhead
Drives: Maggie blown LS3 vette
At mild boost levels, the "efficiency" of the various latest edition belt driven blowers varies very little. The hybrid Roots blowers are pretty good. The stock Whipple is a bigger blower than the Maggie pumping more air. It's not hard to figure out why, when comparing stock vs stock blowers, that the Whipple makes more power. Compare them both at say 9ish psi. There won't be much difference. On an LS3 sized motor, the smaller blower will actually be stronger down low and give up very little on the top end. The 2.3L blower is an excellent match for a 6.2L motor. As you push things harder and the boost goes higher, the bigger blower will eventually have advantages. You probably won't find them on a stock motor.....at least not for very long
old motorhead is offline   Reply With Quote
Old 10-03-2013, 09:38 AM   #3
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Thx!
If I had to do it again I would go with Whipple. I'm not saying the Maggy is bad, I just feel the whipple is a great blower, does well on stock cubes and their is room to grow. I originally only wanted a 2300, and choose the Vortech-Lysholm because of its TQ curves. I'm very happy with my blower. But I wish I went with a Whipple now. I'm going to forge and stroke my motor soon. Then will come the problem where I run out of blower before motor.
Figure out your long term goals. I thought 650rwhp would be enough, and decided it's not. I'm seeing most people are maxing out 700rwhp range +\- 50 with 2300s.
2017 ZL1 A10: Bone Stock.
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 10-03-2013, 10:31 AM   #4
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I've had both and can say I picked up power when I switched to the whipple. On the same dyno I averaged close to 600rwhp with the Maggie and 3.6 pulley, switched to the whipple and averaged 650+rwhp on the 4.0 pulley. Both are good blowers and this debate will go on and on but I really like my whipple!!
MODS:
Old 10-03-2013, 12:13 PM   #5
H-E
Drives: 2010 zr1 Camaro 2011 vert
When you installed the whipple did your boost go up?
H-E is offline   Reply With Quote
Old 10-03-2013, 12:18 PM   #6
old motorhead
The Maggie would need overdriven rear pulleys and a 3.7" front pulley to move the same amount of air as the Whip moves with a 4.0" pulley. Equip a Maggie like that and it would show some pretty comparable power numbers.
Old 10-03-2013, 12:27 PM   #7
bct10985
Drives: 2010 2SS LS3, 2013 duramax
All of us in the forced induction section obviously can never have enough power so y not start off with a bigger blower with room to grow cause your eventually gonna want more. Haha i already want a ysi and havent even maxed out this novi1500 yet.
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 10-03-2013, 12:31 PM   #8
StephenS_84
Drives: 2011 2SS/RS
Whipple is bigger... End of debate.
StephenS_84 is offline   Reply With Quote
Old 10-03-2013, 12:34 PM   #9
old motorhead
True, some never quit wanting more.....but, I'd bet the vast, vast majority either can't afford it, or have no desire to upgrade everything from the front bumber to the rear bumper to accomodate more power than a Maggie can make. Much over 700 and you need motor upgrades, clutch upgrades, tranny, rear end, etc. Saying "all" want to go that route isn't quite right.
Old 10-03-2013, 12:37 PM   #10
10aSSee D
10aSSee D's Avatar
No it stayed the same, both were around 8.5-9psi.
MODS:
Old 10-03-2013, 01:07 PM   #11
NicKey
Drives: Nickey Super Camaro
Both are good quality products. At the same boost level both have similar results.
NicKey is offline   Reply With Quote
Old 10-03-2013, 07:29 PM   #12
Medi0cr3
Medi0cr3's Avatar
Drives: 2011 2SS
great info! Keep it coming!
Night Fury Cam
Tuned by Rhino79
Old 10-03-2013, 08:19 PM   #13
old motorhead
Since this is your thread....what do you want your rig to do? Where do you want to be power wise? Are you thinking forged engine and drivetrain upgrades? It's kind of pointless to try to compare dyno sheets, etc. I have a dyno sheet showing 672 rwhp at a little over 8psi. I upped the boost to a little over 9psi and now have a dyno sheet showing 642 rwhp. If you figure it out, let me know
Old 10-03-2013, 11:28 PM   #14
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
I'm more curious about the difference between the Manacharger 2300 and the Lyshom 2.3 liter(screw type vs roots type).
UNRIVALED SS is offline   Reply With Quote
