Cold Air Inductions
Old 09-29-2013, 02:20 AM   #1
Avoooo
Drives: 2013 agm Zl1
Question regarding suspension
Does suspension really help quarter mile times by a decent margin, or is all suspension work mostly for tracking the car? Not very familiar with all this.
Thanks again
Arh headers, injectors, rotofab cai, lower 9.1 pulley
Avoooo is offline   Reply With Quote
Old 09-29-2013, 09:34 AM   #2
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I think drop springs slow the car down because it makes it too stiff and doesn't allow the car to squat. Coil overs are better than stock only if they allow you to adjust the firmness. Stock suspension is actually really good because it allows the car to squat.
DarkneSS is offline   Reply With Quote
Old 10-03-2013, 03:50 AM   #3
Avoooo
Question about suspension
Asked this in another section got no anwsers, so might as well try here. Ford suspension work really help 1/4 times or is it just for tracking the car?
Old 10-03-2013, 06:48 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Not sure about the Ford reference, but with the right suspension upgrades can definitely improve your quarter mile times. Earlier this year we hooked up one of our local customers with a suspension package and the first pass down the strip he knocked 3 tenths off his previous personal best. And that was on a poorly prepped surface.
Old 10-03-2013, 12:57 PM   #5
Avoooo
Wow didnt even realize I wrote ford lol, I meant does*. And thanks this was the anwser I was looking for, when I'm ready to buy I know who to contact!
Old 10-03-2013, 02:35 PM   #6
Goober
Drives: Camaro
Wow that's some typo. Shame on you.
Goober is offline   Reply With Quote
Old 10-03-2013, 02:53 PM   #7
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Suspension absolutely helps with quarter mile times.
Check with Matt @ FSP who just did this build for a guy who races.
http://www.camaro5.com/forums/showthread.php?t=319255
Being that you are out west though you could also check in with Jordan or Tyler at JDP Motorsports. They are out of Utah and have some experience as well.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 10-03-2013, 03:37 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks again
Suspension definitely helps with quarter mile performance. You should not only see an improvement in times but also in the consistency of the car itself. Now the amount of improvement will vary depending on what parts you install and the car itself but I can tell you with 100% certainty that suspension is very important for getting all the performance out of your car that can at the dragstrip.
Since the Camaros utilize IRS in the rear the goal with modifying the rear suspension is to limit the unwanted movement in the rear cradle, rear suspension, and rear end. Doing this will allow to get the power to the ground for optimal performance and will also keep you from breaking parts due to wheel hop. We have developed many hard parts like trailing arms and toe rods along with a full bushings line to improve the suspension on the late model Camaros.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 10-03-2013, 03:52 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Thanks again
Addressing the soft bushing and deflection in the suspension will help quite a bit in the 1/4. If you really want to get serious, pick up a set of drag coilovers with 2 way adjustable dampening. Feel free to call, PM or email me anytime. We can talk about your goals, what you are looking to spend and get you dialed in.
T.
Thanks for the support T
Best regards,
Tyler
888-308-6007
Old 10-03-2013, 04:14 PM   #10
Apex Motorsports
No problem. That is what we are here for. Look forward to hearing from you.
Old 10-03-2013, 05:17 PM   #11
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Thanks again
This will help you get familiar
5th Gen Wheel Hop and Drag Race Setup
Setup is more important on an IRS than a traditional solid axle because there are so many more variables in an IRS. Now is a good time to talk about wheel hop.
The #1 source of wheel hop on a 5th Gen Camaro is found in the OEM SUB-FRAME bushes. That would be the reason Chevrolet upgrade the sub-frame bushes by partially filling the Noise Vibration and Harshness (NVH) voids starting with the 2012 5th Gen Vert. The OEM sub-frame bushes are still biased toward NVH concerns and not burn-outs, or performance at the drags or road course weekends. The NVH voided original or slightly improved OEM sub-frame bushes allow the entire IRS to shift side to side while under-load. This motion changes the dynamic alignment of your 5th Gen creating rear end steer, rear end step out and contributing to wheel hop
The #2 source of wheel hop, particularly on lowered Camaros is INCORRECT ALIGNMENT. Too much negative camber places the load of launch primarily on the inside shoulder of the rear tire. Spinning an inch and a half strip of tire doesn't take much HP. Aligning your 5th Gen to less than -.5 degrees rear camber with a TOE IN .17 improves your drag launch by using 90% or more of your rear tires to put power down.
The #3 source of wheel hop is deflection in the toe link bushes. We are not talking about toe link arm deflection we are talking about bush squish in the arm. How do I know? Hard engineering data. When GM built the Leno Twin Turbo Camaro they were not satisfied with the handling. Jay's Camaro has a very aggressive set of wheels and tires that increase the load on the suspension. In speaking with some members of the build TEAM I suggested a couple of Pedders upgrades in addition to the Xa coilovers that were already installed at the Milford Proving Grounds. Being a structured and data driven company, the build TEAM decided they should measure and document the issues on a shaker.
You can see a Camaro on GM's Shaker Rig at 55 seconds in.
What were the results of Leno's car on the SHAKER? The data and data points belong to Chevrolet and GM. The EP1200 sub-frame inserts and EP7323 Toe Link Bushes may be on Mr. Leno's Camaro, but they belong to me.
The #4 source of wheel hop on a 5th Gen is the tie and tread compound. Check aorund the forum and see what happends with wheel hop when you run on drag rubber or shorter tires.
The #5 source of wheel hop is a combination of modest spring rate and a damper map biased a bit too much to ride comfort. We spent a long time working with Lingenfelter to develop a dedicated set of drag coilovers. The front coil rate is 4.5kg and the rear is 12kg. The front monotube has a longer stroke than stock. The rear monotube is a massive 52mm diameter unit that is maxed out for bound control. High RWHP Camaros with slicks bite so har the launch is violent. They compres the rear suspension so fast that it bounces off the bumpstops. Keep in mind this was measured using a well known set of brand-x coilovers on the LPE Black Pig. When we bolted on out of the box Pedders Supercars the Black Pig picked up 2/10ths in the 60'. After we tested, refined and tested and.... you get the idea the LPE Drag Coilovers delivered more than 3/10ths improvement in the 60'
The #6 source of wheel hop is related to side to side load distribution. The factory rear sway bar 2010 to 2011 is a 23mm hollow tube that mounts inboard close to the differential. It is a light weight bar by any measure. The 2012 FE4 features an improved sway bar mounting position that is close to the knuckle. This is a HUGE improvement in geometry and function. The ZL1 comes of the assembly line with a 28mm SOLID bar. The change in geometry coupled with the change in bar strength (GM is now using solid sway bars just like Pedders Camaro sway bars) more effectively distribute load on hard launch. Upgrading to OE Rear Lower Control Arms with the new FE4 / ZL1 sway bar mounting points and a ZL1 28mm solid rear bar will imporve your drag launch. If you are looking for even more improvement your ONLY option is Pedders new 2010 to 2011 ZL1 32mm solid rear bar complete with GM ZL1 Arms and Pedders Droplinks. If you have a 2012 all you'll need is the ZL1 Rear Sway Bar Upgrade.
The #7 source of wheel hop is driveline movement. Driveline twist or driveline torque is a mini-wheel-hop motion. Replacing the OEM NVH biased differential bushes is the first place to start. The front two differential bushes are under heavy load, but that load is dwarfed by the load that the rear differential bush carries. Our solution is the new EP1167HDZ. The front two bushes are very high durometer urethane and the rear bush is machined Acetal for maximum control for optimized launches.
When you are serious about your 5th Gen performance on the drag strip your solutions are found at Pedders and Lingenfelter. If you get serious so do we. We provide special support to the LPE Black Pig and her support crew.
