sjm autoprod
Old 10-03-2013, 11:06 AM   #1
SteveV
Drives: 2013 VR Camaro 2SS 1LE
Royal Purple Gear Oil
A number of you have said that in addition to putting Royal Purple Synchromax in your Tremac, you also replaced the gear oil in the rear axle with Royal Purple as well.
What weight did you use? I have seen 75 - 90, 80 - 90, 75 - 140 and 85 - 140.
Thanks in Advance...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 10-03-2013, 11:16 AM   #2
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
I used the 75W-90 Royal Purple Max Gear. Works great and it's the recommended gear oil weight for the rear differential.
PsychoZL1 is offline   Reply With Quote
Old 10-03-2013, 11:24 AM   #3
Deebo
2SS/1LE GAZ 1 of 221
Deebo's Avatar
Drives: 2013 1LE
My '10 SS started making noises immediately after I changed my diff gear oil to 75W/90 Royal Purple. I later went back to my old stand-by, Mobil1, and the noises ceased. I was later informed that, contrary to Royal Purple's claim, a friction modifier needed adding when using their product (?)
...ain't nothing changed
Deebo is offline   Reply With Quote
Old 10-03-2013, 01:12 PM   #4
SteveV
That is good to know. Thanks.
Old 10-03-2013, 02:42 PM   #5
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
//Update: see post #9.// Thats interesting, I just changed my diff oil to 75/90 RP and haven't heard any noise. I didn't add any additional friction modifier either. I suppose each car is different.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-03-2013, 04:33 PM   #6
wpl11972
wpl11972's Avatar
Drives: 1LE
The syncromax has limited slip in it. I've had no problems with it
wpl11972 is offline   Reply With Quote
Old 10-03-2013, 05:09 PM   #7
SteveV
Wait, I thought the tranny fluid was called synchromax. The rear gear oil is called Max-Gear...
Old 10-03-2013, 07:13 PM   #8
jcamo
jcamo's Avatar
Drives: 2ss/rs/2013 camaro 1LE
Thats correct .....stevev
jcamo is offline   Reply With Quote
Old 12-01-2013, 02:13 PM   #9
White_SS/RS
Drives: 14 1LE
Update: At first I wasnt having any noise with the royal purple, for about 200 miles or so, and I dont hear anything when driving around but I am getting a pop from the diff when I back out of my driveway, does it almost every time I leave. I figured I'd add more friction modifier to the diff (3oz, which is half what the bottle recomended)... still does it..... I'll try adding more and see if it helps, but sounds like I'll be switching brands.
LMS Engineering
Old 12-01-2013, 05:49 PM   #10
SteveV
I replaced all 3 of my primary drive fluids with RP Friday, 11/29:
- Max Gear 75w90 in the diff (didn't need to add any additive)
- Synchromax in the tranny
- Royal Purple 5w30 in the Engine.
The shifting has smoothed out quite a bit. No noise out of the diff.
Put 150 miles on her this weekend after doing the fluids on Friday. Running great.
Old 12-02-2013, 10:29 AM   #11
h018871
Geoff
h018871's Avatar
Drives: 2013 1LE Blue
Steve,
A related question: my trans makes noise when the clutch is engaged and in neutral. Not when cold, always once warm though. Did yours have that noise? If so, did the RP eliminate it?
Standard mods: cam, headers, cai..........etc
modifications: http://www.camaro5.com/forums/showthread.php?t=332717
h018871 is offline   Reply With Quote
Old 12-02-2013, 10:07 PM   #12
SteveV
Unfortunately, No. My tranny never made any noise with the clutch in.
Before the Synchromax, it was a little clunky in the 1-2 shift. That is gone now.
Old 12-03-2013, 01:06 PM   #13
h018871
Geoff
h018871's Avatar
Thx Steve
I'll give it a try anyways at the next fluid change
I misspoke earlier, by clutch engaged I meant "foot off of the pedal"
Old 12-03-2013, 02:19 PM   #14
jcamo
jcamo's Avatar
Originally Posted by h018871 View Post
Thx Steve
...... That sounds like the throw out bearing your hearing.
