sjm autoprod
Old 10-03-2013, 01:26 PM   #1
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Clickinn noise when i turn
Hello everyone, I changed out my sway bars 6 months ago and about a month ago my car startig making a click/pop sound every time i turn a corner (1-20mph) Since then i have installed lowered springs but since the sound wad there before I assume it had nothing to do with it. Anyone have this problem or know what is causing it?
DaFisch is offline   Reply With Quote
Old 10-03-2013, 03:21 PM   #2
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Is your blinker on when you are turning the corner?
Kidding... Hope you find a solution!
JTruck is offline   Reply With Quote
Old 10-03-2013, 04:06 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
You could remove your front sway bar end links and tie the sway bar from moving to narrow it down for sure to your bar/bushings/end links. Just don't get crazy!
Caswell239 is offline   Reply With Quote
Old 10-03-2013, 04:16 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
Hi DaFisch,
Were the sway bars installed by your dealership?
Jessica
Chevrolet Customer Care
Old 10-03-2013, 04:45 PM   #5
DaFisch
DaFisch's Avatar
Originally Posted by Chevrolet Customer Svc View Post
Hi DaFisch,
Jessica
No, I had Midas do it, but they were the eibach anti roll ones and it doesn't sound like they are moving or clicking so I doubt it would be that.
Old 10-04-2013, 09:21 AM   #6
Jameg1011
Jameg1011's Avatar
Drives: 2012 2LT 45th anniversary
Is it a constant clicking/ticking sound? Most likely the Differential. How many miles on your car? Might want to replace the fluid with something decent.
Jameg1011 is offline   Reply With Quote
Old 10-04-2013, 09:36 AM   #7
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
Check your link joints to the front sways, one of the Iowa guys just found out this was his popping noise.
its a syn is offline   Reply With Quote
Old 10-04-2013, 04:25 PM   #8
Drives: GM Vehicles
Okay. I would be happy to speak with your dealership further on the issue for you! You may send a private message at any time with your full contact information, VIN, vehicle mileage, and name of preferred dealership. Thank you!
Jessica
Old 10-05-2013, 01:05 PM   #9
DaFisch
DaFisch's Avatar
I have 17700 miles on my car, do you think it could be that?
Old 10-05-2013, 01:22 PM   #10
epstein
Drives: SS/RS
Send a message via AIM to epstein
KISS.....
Check The steering I shaft bolt first .
epstein is offline   Reply With Quote
Old 10-05-2013, 05:23 PM   #11
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I have the same thing happening on mine, with the same sways/spring kit as you. Mine didn't start until 3 years after those were installed though, so I kind of doubt it's that.
I'm going to be taking mine in soon to have a shop look at it. Hopefully nothing too expensive.
[B]
Old 01-07-2014, 10:34 PM   #12
Mcfly
Drives: 2014 2SS LS3
I had the same problem, with 18k miles... took it to the dealer and they replaced the front bearing and hub under the factory warranty. Never heard the clicking again!
Mcfly is offline   Reply With Quote
