HeadlightArmor
Old 10-03-2013, 05:13 PM   #1
Revster
Drives: 2015 ZL1
Question Oil Leak
Had my 2010 SS on a hoist for axle back Borla install I saw oil near the oil filter, found the two bolts on the oil filter mount were not completely tight, I tightened them and am going to keep an eye on it. I have put 40 miles on it since and seems to be no more leak.
I just wondered if anyone else has had this problem?
Revster is offline   Reply With Quote
Old 10-03-2013, 05:53 PM   #2
ECCamaro
High Desert Camaro Man
ECCamaro's Avatar
Drives: White Convertible-Tan Top 2SS V8
I have not had that problem. Have you performed all of your oil changes yourself or have you had others do it? If you had others do it, is it possible they could have loosened the bolts.
ECCamaro is offline   Reply With Quote
Old 10-03-2013, 06:07 PM   #3
Revster
Drives: 2015 ZL1
Local dealer has done all service work, car has only 13000 miles on it.
