JDP Motorsports
Old 10-03-2013, 07:17 PM   #1
alv927
alv927's Avatar
Drives: 2013 camaro 2ss/rs dusk edition
engine balancing
Does anyone know what goes into balancing an engine and what kinds of hp gains are expected if any?
alv927 is offline   Reply With Quote
Old 10-03-2013, 08:58 PM   #2
thirdgenlsx
thirdgenlsx's Avatar
Drives: 2012 2ls
Its done on a crank balancer. It basically is a big drill press so you can drill the counter weights (remove weight) Matching the counter weights on the crank with the weight of the rods,pistons,rings,wrist pin and rod bearings
Most LS engines are pretty balanced within 10 grams or so I have seen a few 30 grams out
The lighter the rotating assembly the quicker the revs can be and the smoother it will run and cuts down on wear...]
I BALANCE ALL CRANKS WITHIN 2 grams
Alot of aftermarket cranks mostly when the rods and pistons are light weight you have to add weight to the counter weights
2012 Camaro 2ls DD
1987 Camaro sport coupe lsx forged internals (in progress)
1994 GMC sierra 360 sbc ported intake and TBI big block injectors (tuned)
thirdgenlsx is offline   Reply With Quote
