HeadlightArmor
View Poll Results: which blower cam
jre rough idle 19 22.89%
ecs big blower 7 8.43%
lethal night fury 13 15.66%
texas speed blower 7 8.43%
custom grind 37 44.58%
Voters: 83. You may not vote on this poll
Old 10-04-2013, 09:25 AM   #1
bct10985
Drives: 2010 2SS LS3, 2013 duramax
blower cam poll
Trying to figure out how to do a poll. Which blower cam would you choose. Jre rough idle, ecs big blower, night fury, tsp blower, or custom grind.
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 10-04-2013, 10:55 AM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Custom spec from Pat Guerra here.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 10-04-2013, 11:16 AM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Custom grind from the guys at Texas Speed here.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-04-2013, 11:23 AM   #4
grocerygetter
instigator
grocerygetter's Avatar
see my thread over in engines...110whp gain on a GPI vvt grind...but I'm guessing you have an LS3...your loss.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 10-04-2013, 11:29 AM   #5
East Coast Supercharging
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
I voted for the ECS cam, because they are the best.
East Coast Supercharging is offline   Reply With Quote
Old 10-04-2013, 11:31 AM   #6
bct10985
You guys with custom grinds have more cubes right. Im still stock. Im not sure im at the level that needs a "custom" grind. Im sure all these companies that have blower cams did there homework and didnt just pull #s out of thin air. And when you get a cam specced for you is it going to be more aggressive than an "off the shelf" grind? I dont want to be replacing valvesprings every few months. Also how much detail do you think these people that spec out cams go into. Lets say this guy has 2" headers, 12 psi and someone else has 1 7/8" , 10 psi. Are the cam specs going to be different. I doubt it
Old 10-04-2013, 11:36 AM   #7
2SS45th
2SS45th's Avatar
There is more power to be had with a custom grind on any size motor, 400+ cubes or not. A custom grind is typically more aggressive than off the shelf, but that is becasue I would argue that most custom cams are going in cars that want that. A custom cam is just that CUSTOM. It can be ground anyway you or the builder wants.
The cam specs will be slightly different between those two cars if you are going to maximize the setup. But they would be damn close, yes.
Off the shelf cams are good, but custom costs the same. Why put a universal part on your custom build?
Old 10-04-2013, 11:36 AM   #8
2SS45th
2SS45th's Avatar
Old 10-04-2013, 11:45 AM   #9
mropus
mropus's Avatar
Drives: 2010 black 2ssrs
vengeance custom grind
you can identify a vengeance car by the sound of their custom ground cams
Mr. Opus
mropus is offline   Reply With Quote
Old 10-04-2013, 11:56 AM   #10
You guys do realise that all the cams listed are "custom grinds" right?
Old 10-04-2013, 12:01 PM   #11
Camper
Banned
Drives: 10' 2SS LS3 M6
LOL @ post #9
Camper is offline   Reply With Quote
Old 10-04-2013, 12:02 PM   #12
2SS45th
2SS45th's Avatar
Yes, but not in the sense that the are custom ground for your specific build.
Old 10-04-2013, 12:07 PM   #13
Camper
Banned
if you have a ECS blower setup why wouldnt you work with ECS or someone like FSP that has a ton of experience with their own blowers? im sure a ton of R&D has gone into it.
Old 10-04-2013, 12:44 PM   #14
grocerygetter
instigator
To the OP...you need to talk to your tuner and see what he likes and wants to tune.
-John S.
Thanks to:
Tony@ dv8motoring
